1st let me start by saying I am in no way a Unix person. The closest I came to using unix was programing terminal servers way back when. So here is the problems I am having:
I download the nookhoney04.img.zip file on to my Mac. When it finishes it starts to unzip itself automatically and I get a disk icon on my desktop, one that is "boot" the other is "sdcard". I put in my new 8G SD card and it shows on the desktop as "NO NAME". I copied the terminal screen so you can see what I am seeing when following your instructions:
Last login: Thu Mar 3 14:11:05 on console
new-host-2:~ ebphoto$ diskutil list
/dev/disk0
#: TYPE NAME SIZE IDENTIFIER
0: GUID_partition_scheme *320.1 GB disk0
1: EFI 209.7 MB disk0s1
2: Apple_HFS Macintosh HD 319.7 GB disk0s2
/dev/disk1
0: Apple_partition_scheme *2.0 TB disk1
1: Apple_partition_map 32.3 KB disk1s1
2: Apple_HFS Seagate 2Gig 2.0 TB disk1s3
/dev/disk2
0: GUID_partition_scheme *1.0 TB disk2
1: EFI 209.7 MB disk2s1
2: Apple_HFS FreeAgent Drive 999.9 GB disk2s2
/dev/disk3
0: Apple_partition_scheme *15.2 GB disk3
1: Apple_partition_map 32.3 KB disk3s1
2: Apple_HFSX ebphoto 15.2 GB disk3s2
/dev/disk0
/dev/disk1
/dev/disk2
/dev/disk3
/dev/disk4
0: FDisk_partition_scheme *3.7 GB disk4
1: Windows_FAT_32 boot 123.3 MB disk4s1
2: Linux 699.1 MB disk4s2
3: Linux 699.1 MB disk4s3
4: Windows_FAT_32 sdcard 1.3 GB disk4s4
/dev/disk5
0: FDisk_partition_scheme *7.9 GB disk5
1: DOS_FAT_32 NO NAME 7.9 GB disk5s1
new-host-2:~ ebphoto$ diskutil unmountDisk/dev/disk5
diskutil: did not recognize verb "unmountDisk/dev/disk5"; type "diskutil" for a list
new-host-2:~ ebphoto$ diskutil unmountdisk /dev/disk5
Unmount of all volumes on disk5 was successful
new-host-2:~ ebphoto$ dd if=nookhoney04.img of=/dev/rdisk5 bs=1m
dd: nookhoney04.img: No such file or directory
So as yo can see from above, it didn't work. I tried several time but each failed. Sorry if these are dumb questions but like I said I'm not a Unix or programmer. I even copied the nookhoney.img file onto my desktop to see if that would help but it didn't make a difference. I would really like to get this up and running on my NookColor from the SD card. Any help would be greatly appreciated. Please let me know what I'm doing wrong?
Thank you,
Eric
/dev/disk0
/dev/disk1
/dev/disk2
/dev/disk3
/dev/disk0
/dev/disk1
/dev/disk2
/dev/disk3
/dev/disk4
/dev/disk5
Thank you,
Eric
