Results 1 to 12 of 12
- 03-08-2011, 10:41 PM
Thread Author #1
Reversed audio channels??
I was curious if anyone else has had issue with the audio channels being reversed on their nook. It's a little disorienting to be watching a movie and have sound coming from the left when the visual onscreen has it coming from the right.
Actually, I also had another issue where the audio was much louder on the right side, but strangely after I played an audio .mp3 and went back to the movie the problem fixed itself. Weird.
So about the reversed channels...is that a common glitch with the NC's?? - 03-16-2011, 12:03 AM
Thread Author #2
anyone??
i just received a replacement from B&N and it has the same problem. i test the files on my computer and they play correctly so its definitely the NC. WTH? - 03-16-2011, 05:35 PM #3
Very Curious - I'll have to look into that with mine.
Thanks for bringing that to our attention. - 03-16-2011, 11:30 PM
Thread Author #4
yes please test it out on your NC and report back. this is actually the third NC i've had. the first one i got at best buy but returned it within a couple days due to the $200 sale in the B&N Ebay store. sadly i can't remember if the first NC i had did the same thing or not. regardless, for sure the 2 i've gotten from B&N reverse the audio channels and it drives me nuts.
- 03-17-2011, 06:40 AM #5
Blackberry used to do this so you had to use their headsets. I wonder if B&N is taking the same proprietary approach?
- 03-18-2011, 12:18 AM
Thread Author #6
that would be interesting. i'm not gonna assume anything until other people check this out and we see if its just a bad batch or if its all nooks. its quite disorienting when, for instance, someone in the movie on the left side of the screen slams a door but you hear it in the right ear.
- 04-07-2011, 09:41 PM #7
- 04-08-2011, 04:46 AM
Thread Author #8
- 04-09-2011, 03:02 PM #9
- 04-10-2011, 08:18 AM
Thread Author #10
- 04-10-2011, 09:17 PM #11
- 04-14-2011, 01:08 AM #12
Reply
