Results 1 to 3 of 3
- 03-15-2011, 09:34 PM
Thread Author #1
Cellular related battery usage problem on Rooted Stock?
I see on my stock rooted NC that the biggest battery user is related to celluar applications which I obviously don't need. Reading the Nookie Froyo work around thread, I see some instructions for how to remove/rename and invalidate the files that are the issue here.
Will the same work around work on the rooted stock configuration? Can I get the Root Explorer app and fix this by renaming the files that way?
Thanks,
Brian - 03-15-2011, 10:12 PM #2
- 03-16-2011, 05:38 PM #3
Reply
