Results 1 to 3 of 3
    BlueDude82's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Help! 4GB Internal Storage!
    Man I messed up bad this time! I installed a dual boot of honeycomb on my nook and in the process I ended up with two separate partitions that just wont go away now that I've decided to try and go back to a stock nook color! Nothing I do seems to work. I've tried flashing the remove dual boot zip, flashing a remove partition,restore stock zip, hard resetting, etc, and nothing so far. The best I can do it seems is to get my nook back to stock but the internal storage is only 3.97gb (or so). Even my computer will only see two separate 4gb drives (when I managed to get them mounted while still having honeycomb) and won't let me erase and merge them back together. I'm really in over my head on this one. Someone please help!!!
  2. #2
    saulleibow's Avatar
    Posts
    Global Posts
    271 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Try This
    Here's what I did when I was in a similar situation, good luck.
    YouTube - huskermania's Channel
    BlueDude82's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Thanks. Tried that already.....no dice. I think I'm hosed.
Tags for this Thread
