Results 1 to 3 of 3
    Default Clock speed on NC...how to check?
    How can I check my current CPU speed? I am running CM7 off of a card on my NC......
    Thanks!
  2. #2
    rphillipps16's Avatar
    Posts
    ROM
    Stock Rooted
    Default
    I'm not sure if you can check the current speed, but you can set the min and max by going into settings then cyanogenmod settings then performance then cpu speed. I highly suggest you try out the 1.3 GHz kernel if you haven't yet
    Default Hmmm...
    Quote Originally Posted by rphillipps16 View Post
    Is it really that much improved? I found on the cm7 I am running 800 MHz....
