harish7447
Tried it on my G2x, EB1.0.4Froyo ROM. Says "Hulu requires Flash Player 10.0.32 or higher..."
I get the same error!
This definitely didn't work but I do love that browser now. Hahahah... When I go to hulu.com is states "Hulu requires Flash Player 10.0.32 or higher. Please downlo....." I followed the directions to a T and everything seemed to install/work fine. I'm on a Dell Streak running Froyo 2.2.2. It seems it's something to do with hulu.com not recognizing that I have Flash (your version 10.3) installed. My Netflix still works great though with your edited version of Flash. So at least it didn't break anything.
Any idea's?
I got that to... try installing flash from system/app. Worked after that.
Also, Netflix doesn't use flash to work, so it wouldn't affect it at all. All this is doing is hex editing the flash player and browser to make hulu think a windows pc is accessing it.
"try installing flash from system/app" - Can yu please explain what this is?
OP: what os do you have? Is it rooted?
edit: I see you have CM7 installed. is on the sd? is your nook rooted?
I'm on HC on sd card, unrooted. I installed flash & dolphin hd. But I'm getting Flash is required on hulu. Please help!
Thanks
