I looked on the forum to see if there was an answer to do this, but didn't find one that matched my issue. I am running CM7 stable on SD but had this issue on the stock as well. I love CM7 except for this issue. My wifi connection drops constantly. The longest I think I have had it stay connected is about 10 minutes of use. Then it will drop and I have to go back in to settings to have it recconect. Sometimes it will drop the connection after 30 seconds of use. It is really frustrating to have to keep backing out of apps to reconnect the wifi.
I tried using Soft Locker but that hasn't worked. Does anyone have a solution they can provide? Could it be my router? Or is my nook defective?
