Results 1 to 3 of 3
    Default AC Charger makes a high pitch sound when connected, Is this normal?
    I noticed a high pitch sound coming from the AC charger when connected.
    The sound is faint so you can only hear it when there is no other sound in the area.
    Is this normal or do I just have a bad charger?
  2. #2
    Default Re: AC Charger makes a high pitch sound when connected, Is this normal?
    The charger for my Acer A100 does that only when it isn't actively charging the device. So I hear a buzzing when it's plugged into the wall but not connected to the tablet, or when the tablet is fully charged but still connected to the charger. I don't think it's a bad sign.
    Thanked by:
  3. #3
    D-Caf's Avatar
    Posts
    Global Posts
    261 Global Posts
    ROM
    4.0.3/1.4.3/4.1.2
    It's "probably" ok, but if it's annoying I would see if you can take it to a Barnes and Noble and get it swapped out. I have not carefully listened to my charger, but I've never noticed any high pitched sound from it (that or my hearing is just shot). Generally in electronics if there is a sound from it is either: badly designed/constructed, old and warn out, or the outlet it's plugged into is providing voltage/current out of spec or badly grounded.
    ______________________________________________________________________________________
    Current Devices: Nook HD+ 32GB / Nexus 5 32GB
    Past Devices: Samsung Captivate / Nook Color / Nexus 7 16GB (2012) / Samsung GS2 International
    Thanked by:
  1. [Guide] [Info] Custom recoveries versus Stock. Is there a difference?
    By Golfdriver97 in forum Ambassador Guides, Tips & How-To's
    Last Post: 05-04-2014, 07:59 PM
  2. Why is my battery draining when phone isn't being used?
    By Stav Edgar in forum Samsung Galaxy S4
    Last Post: 07-23-2013, 05:24 PM
  3. The black border of my lens is scrached what should I do?
    By Ammar Ashoor in forum Samsung Galaxy S3
    Last Post: 07-22-2013, 10:53 AM
  4. What app is putting ads in notification bar?
    By thehyperone in forum Android 2.3 Gingerbread
    Last Post: 07-22-2013, 08:55 AM
  5. Is it possible to root htc view 4g with hdboot 1.14
    By deindichter in forum General Help and How To
    Last Post: 07-22-2013, 12:31 AM
