07-08-2015 01:15 AM
36 12
tools
  1. ALCingularUser's Avatar
    I don't know why this fixed my problem, but I did a factory reset of my Note 2, then reinstalled BBM, along with all the other apps I had on there. Well, I say it fixed it, but, since I have no contacts in BBM, it's just sitting there, doing nothing. I'll have a better idea if and when I can actually use it.
    10-30-2013 09:10 PM
  2. Prem Acharya's Avatar
    Well, I got BBM installed and my BlackBerry ID set up last night. No one to chat with yet, but I really haven't had time yet anyway, so no big deal. However, it does seem like my Note 2's battery is draining a bit faster than before. Is anyone else noticing this?
    I too noticed that the battery is draining quite faster after installing bbm on my Note 2
    11-01-2013 05:50 AM
  3. davevarun's Avatar
    I have a Galaxy S3. Battery drain is very fast and charging speed has also reduced.
    I left my S3 at 100% last night at 10.30pm on a stand-by mode. Battery drained to 25% by morning 7.00am.
    BBM is killing my S3.
    11-07-2013 03:41 AM
  4. parthshrey's Avatar
    If u are not a very hardcore user of bbm, i suggest you to toggle off the bbm connected icon in the settings. It works fine that way too. Helped me with my nexus 4.
    Sent from my Nexus 4 using Tapatalk
    11-07-2013 03:48 AM
  5. ALCingularUser's Avatar
    The company tweeted yesterday that an app update is coming, but no specifics. At Cheddars, one of the testers is saying they're working on version .90, which he said has tons of fixes and improvements. Hopefully, this issue is addressed in there.
    11-07-2013 02:26 PM
  6. ALCingularUser's Avatar
    BlackBerry released an update this afternoon that they claim addresses the battery drain issue. I guess we'll see.
    Version is 1.0.2.83.
    11-14-2013 03:51 PM
  7. TeknoBug's Avatar
    Yup just installed BBM on my Moto X the other day so I can talk to a friend through BBM and noticed a significant amount of battery drain, I used my Moto X like normal and barely even used BBM for day yesterday and it ended up at 33% battery by 6pm (where it would normally be ~50%), but BBM isn't very high on the battery usage list.
    02-01-2014 05:40 AM
  8. mzanette's Avatar
    Just installed, i'll keep an eye out for battery drain
    02-14-2014 03:29 PM
  9. GreekboyD's Avatar
    Yo dawg. How bad be this drain?
    02-14-2014 03:32 PM
  10. mzanette's Avatar
    Haven't noticed any extra battery drain, then again I've only received one bbm message in the last 3-4 days.
    02-17-2014 10:04 AM
  11. Touchone Touchall's Avatar
    i had a little battery drain problem of BBM on Android 4.4 on OnePlus, but since upgraded to Android 5.0+, the battery problem seems to be solved.
    07-08-2015 01:15 AM
36 12
  1. Verizon Droid DNA - nfc on, check, android beam not working
    By sparkeater79 in forum Verizon Droid DNA
    Last Post: 10-24-2013, 04:17 PM
  2. Verizon Galaxy Note 2 - battery monitor help
    By Jonathan Rodriguez3 in forum Verizon Galaxy Note 2
    Last Post: 10-24-2013, 11:59 AM
  3. Help Upgrading LG Lucid 2 VS870 to Android 4.2.2
    By Kevin Colwell in forum General Help and How To
    Last Post: 10-23-2013, 10:21 PM
  4. BBM To Nexus 7
    By seamonky in forum Google Nexus 7 Tablet (2013)
    Last Post: 10-22-2013, 03:13 PM
  5. Android OS as Metro app - Make it happen Google!
    By cwright9 in forum General News & Discussion
    Last Post: 10-22-2013, 08:40 AM
