Results 1 to 8 of 8
Like Tree1Likes
  • 1 Post By trailblazen
    Default Extended Battery Questions
    Will the extended door make all the accessories not fit? Car Dock, Media Dock, will there be a battery charging station for the extended battery?
  2. #2
    KillerG's Avatar
    Posts
    ROM
    AOKP JB
    Default Re: Extended Battery Questions
    It's not that much bigger than the actual battery door, so I would HOPE it wouldn't fit. Couldn't tell you offhand though, but I would say yes, it should fit. As long is the phone had a little wiggle room in the first place.
    There's a new phone that will run Crysis on Ultra at 120 fps on a 2160p display that's coming out 3 months after you buy your next phone.
  3. #3
    Quote Originally Posted by gjira View Post
    The droid x still fit in, it had a piece you could remove so it fit better in the car dock.
  4. #4
    during my chat with my friend tonight he said the extended batteries and certain cases will fit the docks just fine since they are designed for ext. batts and most but not all cases.
    I'd bet Cory's Right Arm on that!
    -Grandfathered Unlimited-
    Thanked by:
    corymcnutt likes this.
  5. #5
    shadrap's Avatar
    Posts
    Global Posts
    283 Global Posts
    I would really like to know this also. Does it fit in the dock and nav dock with extended battery.
  6. #6
    yeah he said all docks will fit with the extended. there are at least a case or two that will fit with the extended. Thing is I am unsure cased with extended would fit or not. would probably just have to wait and see.
  7. #7
    OMFG I just saw on an accessory page that the extended battery is a 2880mAh battery. Thats massive
    Post 1556 in hofo:
    Thanked by:
  8. #8
    DefectiveWeeble's Avatar
    Posts
    ROM
    Eclipse 2.0
    Quote Originally Posted by trailblazen View Post
    Post 1556 in hofo:
    Holy monkey lovin'! That's gigundous! Now I'm even more excited for my appointment on Thursday. I'm going to have to see if they have these in stock. I'll probably check out the shape of the original battery first, but still great to know! Thanks!
    There are no personal problems which cannot be solved through suitable application of high explosives.
