Results 1 to 7 of 7
    Default Extended battery Charge Times
    Anyone else noticing that the extended battery is taking a very long time to charge? I am new to actually using an extended battery with any phone but its just something I noticed.
    It could be just me being impatient and playing with it too much while it charges. :P
  2. #2
    Default Re: Extended battery Charge Times
    Well I don't have an extended battery myself but considering the stock battery takes 2 hours to charge and the extended battery is almost twice the capacity it makes sense that it will take a while to charge up. That should be normal. If you want your phone to last a long time, the bigger battery is going to take longer to charge up.
    I think its just me being impatient
  4. #4
    Took me about 3 hours to fully charge from literally 1% to 100% with the regular battery but I had the phone on. If it was off obviously it would've charged faster.
    I am in the process of charging the extended right now 1.5 hrs into the charge with the phone on and it just hit 30%.
  5. #5
    Traprock's Avatar
    Posts
    Global Posts
    52 Global Posts
    I've noticed that, but I'm hoping it means it willl last forever when fully charged :P
  6. #6
    WM6.5 supports fully extended battery without problems. Is that right???
  7. #7
    I honestly haven't couldn't tell you how long it takes for mine to charge up mainly because I charge mine overnight. Guess I should do a test run and see.
