Results 1 to 10 of 10
- 09-10-2011, 03:35 PM
Thread Author #1
- 09-10-2011, 03:44 PM #2
Re: Mili Extended Battery For Bionic
Well, its like carrying around a 2nd phone, so if you like that feeling go for it. haha.
Seriously though, its just a big battery with a charging plug on it from what i gather. So a portable charger. You would use your phone and when it gets low, plug it in just like any other charger and it'll charge your phone up... and even when fully charged... it would keep it charged if you leave it attached while using it.Judgement Day is upon us!!!!.. Bionic has gone online and became self-aware.. awaiting destruction in 3..2.. - 09-10-2011, 03:49 PM
Thread Author #3
- 09-10-2011, 03:51 PM #4
It looks cool and I could certainly see something like that being perfect for the right person, but that seems a bit pricy to me. Now 8000mAh is great, but I often find specs like that are insanely over rated.
If you think it looks like something that would come in handy, maybe you spend a good amount of time not near a power source, I would recommend shopping around and looking for independent reviews. - 09-10-2011, 03:55 PM
Thread Author #5
- 09-10-2011, 07:43 PM #6
Cool idea, and it's something I would consider for a tablet maybe, but for a phone, I'd rather just carry a charger around. Much smaller. I would suggest trying the extended battery before you go whole hog on this bad boy.
There are no personal problems which cannot be solved through suitable application of high explosives.
- 09-10-2011, 11:19 PM #7
Yeah my friend had a smaller one of something like this for his Droid X, he was using at DisneyWorld to keep it charged through the day. We always got terrible reception inside attractions so his battery would go pretty quickly. It's a cool thing to have, I would go with something lighter and cheaper...and just stuff it in a bag until you need it.
There's a new phone that will run Crysis on Ultra at 120 fps on a 2160p display that's coming out 3 months after you buy your next phone. - 09-28-2011, 11:18 AM #8
I can tell you external batteries work well. (Energizer XP18000) However, the real question is if you are disciplined enough to carry it. It's like buying a DSLR instead of a point and shoot. If the point and shot does what you need, are you really going to lug around the DSLR everywhere you go? And then, that one moment you really need the DSLR, you left it in the car. >.<
IMO, get the extended battery and keep the standard battery as backup. It's smaller, no additional charge, and extremely simple.
If you're you carry a piece of luggage with you everywhere you go and either watch hours of video or are away from your charger for days at a time, go for it.
Sent from my DROID BIONIC using Tapatalk - 09-28-2011, 11:27 AM #9
vzw has something similar. i bought mine half off when i bought my bionic. never used just looked for it not sure where it is. but yea phone plugs and it gets charged. fyi i also have two a extended battery a spare battery charger and two stock batteries. im ready for the event.
Google Nexus Class Devices (Nexus7, Nexus4, Galaxy Nexus lte VZW)...@moosc on twitter ...
- 09-28-2011, 01:27 PM #10
I picked this one up from Anker - Amazon.com: Anker Power Bank 5000mAh Li-ion External Battery Pack and Charger for Motorola Atrix 4G, Photon 4G, Defy; Motorola Droid, Droid 2, Droid 2 Global Droid 3, Droid X, Droid X2, Droid Pro, Droid Bionic; Motorola A855, Backflip, CLIQ 2, Charm,. It's rated for 5000 mAh, but I think that's overstated. The good: It's small, portable, relatively easy to use, and comes with a variety of attachments (NOT one, however, that will also work with my Xoom). The bad: I used it to recharge my phone while out playing golf. I had the standard battery in, with a 40% charge when I started. It charged my phone fully in about an hour, but was down to less than 20% charge itself. I'm no electrical engineer, but since the standard battery is rated at 1735 mAh, I would have expected the Anker to still have capacity after fully charging my phone.
Nevertheless, it works - I'll just have to find another solution for my 3 day camping trips w/out power access where I use the phone as an MP3 player.
Reply
