1. SpaceCracker's Avatar
    Please post any case that might fit with the extended battery on the phone besides the holster one they sell in the Verizon store here...
    So far I have not found any.
    09-13-2011 10:52 PM
  2. CobbFC09's Avatar
    I don't think there are any.
    09-13-2011 10:57 PM
  3. blackcat55's Avatar
    The leather case from verizon fits the Bionic with or without the extended battery well. Easy to clip on belt and remove with one hand action. Android Central has it on sale!!
    09-14-2011 01:58 PM
  4. GBH2's Avatar
    Not really a case. But it is like "Invisible Shield".
    Optishieldz Clear Protector - full body protection
    Go to the full body kit page and there is an option(same price) for a kit for the Bionic with extended battery.
    I am considering it. Maybe that and a leather case.
    optiSHIELDZ | Item Detail
    09-14-2011 04:57 PM
  5. IRSmurf's Avatar
    Since I've seen the question asked a few times here, I'm confirming the OtterBox case is not compatible with Droid Bionic's extended battery: http://m.zdnet.com/blog/perlow/otter...d-bionic/18737
    Sent from my DROID BIONIC using Tapatalk
    09-28-2011 11:09 AM
  6. just1083's Avatar
    The shell/holster combo that you can get at the Verizon store is compatible with the extended battery, I just picked one up today.
    09-29-2011 04:47 PM
  7. CobbFC09's Avatar
    How do you like it?
    09-29-2011 05:08 PM
  8. azreed2000's Avatar
    I like mine... It gets the job done and it also has a convenient stand that will hold the phone up in either portrait or landscape mode. It also works well to protect the phone against drops and scratches (but I still recommend some type of screen protector... I went w/ the Zagg). I dropped my phone a few days ago in a parking lot... and while trying to catch it I made it worse by slapping it away from me. I watched in horror as it slid across the asphault (face down, of course)... but I was happy to see that there wasn't a single scratch on the phone and the case weathered the abuse with barely any scractches itself.
    I'm not a big fan of the belt holder it comes with... it kinda sticks a bit when I'm trying to pull the phone out but, I guess it beats it falling out on its own.
    10-01-2011 02:25 PM
  9. spectre1006's Avatar
    the wait continues... Come on incipio or seidio!
    10-06-2011 08:57 PM
  10. freeky1's Avatar
    Still checking every day...
    10-07-2011 09:55 AM
  11. Arelunde's Avatar
    I have this combo and it's ok. Not very sexy and very black. But efficient and feels good/solid to hold. The hard-to-pull out factor is an easy fix. Superglue a thin strip of felt (or whatever you have) in the two lower corners of the holster - just enough to keep the Bionic from going that last 1/8 inch where the holster grabs it tightly. It's still in the holster solidly, but can be pulled out without having to yank it with two hands.
    10-07-2011 10:19 AM
