09-14-2012 08:44 PM
41 12
tools
  1. rhull3's Avatar
    Can u heat it to for the case to mold to it?
    10-20-2011 09:58 AM
  2. rhull3's Avatar
    Had that thought but hadn't tried it yet, I'll attempt ASAP it and post results.
    10-20-2011 09:59 AM
  3. rhull3's Avatar
    Sorry I never followed up. I lost my cover and and never replaced it hoping for an Otterbox or something similar . Anyone find a case yet?
    12-03-2011 05:07 PM
  4. akorcovelos's Avatar
    12-03-2011 06:13 PM
  5. BBSeattle's Avatar
    Great tip, thanks! I tried the bottom but found it worked better with the felt in the top corners.
    Purchased little felt sticky back dots from ACE Hardware. Works like a charm. I can finally get the phone out with ease when attached to my belt.
    I like the Vz case for the extended battery and have no issues with it being open at the top and bottom - but I don't generally have it in a situation where damage could occur (other than dropping it). It does have a nice feel to it and I really like the holster (slim and efficient). The Bionic is hard to pull out of the case, so I glued a small layer of felt at the bottom edge of the holster to keep the Bionic from going the last 1/8th inch. Still held firmly in the case, but not so tough to get out.
    Wish they made the case in colors. The Bionic is awfully BLACK when the screen is off. I've accidentally left it places because it sort of blends in to the scenery, being so dark. But, for the extended battery size, there aren't any other options as yet.
    12-11-2011 09:38 PM
  6. LoneWolf15's Avatar
    There aren't any cases that will allow you to use the dock with the case on.
    While I haven't used it myself, I hear that TPUCases extended battery case will work with the docks (provided you remove the plastic insert in the dock that is there for phones without the extended battery.
    Motorola Droid Bionic : TPU-CASES.COM, - All TPU Cases Shipped Free in the USA
    I would buy one of these in a heartbeat, but I want a version with a belt clip. Currently, I'm using the Body Glove shell case with the clip, but I'd like to get the extended battery. I wish they made one of these with the hump for the extended battery.
    I think my only solution (not my personal favorite, but the best I'll get) is to get a leather pouch case with a clip. That will allow the extended battery easily. The one downside to that is that when it's not on your hip, you have a naked phone. Either that, or the TPU case on the phone, and a leather pouch case as well that will hold the phone that way.
    I'm not a fan of the extended battery case Verizon offers. It's always seemed chintzy, and I dislike the exterior design (I'd much prefer plain, smooth, black). To each their own, though.
    12-24-2011 01:10 PM
  7. LoneWolf15's Avatar
    I can now provide more information on this matter.
    I purchased both the Verizon-offered Droid Extended Battery case with holster and the TPUCases extended battery case. I bought both on Amazon, as Verizon's chosen case can be found (in OEM packaging) at a fraction of the VZW price.
    The TPU Bionic case is better than the Extended Battery case, as it provides better coverage of the phone. The bonus is, it fits the Verizon holster AND it fits in both the Motorola-branded Standard Dock and Car Dock, provided you remove the inserts
    Links to the items I purchased:
    Verizon OEM extended battery case with holster:
    Amazon.com: Motorola Droid Bionic XT875 Extended Battery Case Holster Shell Combo with Kickstand: Cell Phones & Accessories
    TPU Cases case:
    http://www.amazon.com/Diztronic-Flex...cUvbUpU1520264
    Note: The TPU cases case is also available in a smoke (semi-transparent) color rather than standard black, but I wanted a match to the holster, and the black case turns out to be an exact color match.
    I hope this helps any of you wishing to find a case that does it all, working with the extended battery and fitting Motorola's docks.
    12-28-2011 10:05 PM
  8. crspy's Avatar
    can anyone else confirm the tpu bionic case with extended battery fits the standard dock?
    01-12-2012 06:06 PM
  9. RichardAnderson's Avatar
    you can see in this web fortte maybe you can find what you search, I have a case for my cell with extended battery and is pretty look it the models
    03-08-2012 07:19 AM
  10. cordoni's Avatar
    Any hard cases anyone has found?
    Sent from my DROID BIONIC using Tapatalk
    03-24-2012 03:05 PM
  11. CobbFC09's Avatar
    Haven't been looking around since I am satisfied with my TPU case, but I don't know of any hard cases. Sorry.
    cordoni and Ry like this.
    03-24-2012 07:37 PM
  12. hector11's Avatar
    nice site fortte the cases looks very strong and elegant you shold be take a look
    04-04-2012 10:08 AM
  13. waynemhscott's Avatar
    Just found this new one on amazon:
    http://www.amazon.com/gp/aw/d/B0084X...cUvbUpU1828121
    Kinda surprising that anyone would bother coming out with a new case for the bionic this late, let alone a case for the extended battery, but thank god somebody did, it's nice to have more than 2 choices
    06-03-2012 09:43 PM
  14. martinfan611's Avatar
    You can use the extended battery with the droid bionic without the extended battery cover
    Sent from my DROID BIONIC using Android Central Forums
    08-08-2012 01:43 PM
  15. tedbearclaw's Avatar
    Just received my tpu case. Very impressed for a $9 case. Glad to be using the extended battery again
    08-21-2012 08:03 PM
  16. TOPshogun's Avatar
    I have the extended battery from Motorola I got off amazon.com for cheap and also a case that fits perfectly I'm sure if you look on there for extended battery cases you would find a good one.
    09-14-2012 08:44 PM
41 12
