1. sniffs's Avatar
    So my battery says it's a 1735mAH 6.6wH a min, it came with the Bionic when I ordered it.
    According to Verizon's site, they are now 1785mAH.. I want that extra size!!
    02-28-2012 12:04 PM
  2. gorgalis's Avatar
    You would never notice the difference. It is 2.8 % bigger, that means that when you are at 20% battery life with the 1735 battery, you would be at 20.56% with the 1785 battery.
    And anyway, it is probably just a typo.
    02-28-2012 12:29 PM
