Results 1 to 2 of 2
- 08-19-2012, 10:54 AM
Thread Author #1
Extended battery compatible with Otterbox Defender case
Is there an extended capacity battery that does NOT require an aftermarket battery cover? I use an Otterbox Defender case so I need a battery that has the same physical dimensions but with higher capacity. I have ordered one that has 2300, but have not received it yet. It's supposedly compatible with the factory battery cover.
- 11-02-2012, 06:44 AM #2
Re: Extended battery compatible with Otterbox Defender case
I believe I saw a hack on youtube of a guy using a dremel to cut the back of the plastic otterbox case to fit the extended battery cover. He then claims the rubber cover will slip over the case.
Sent from my DROID BIONIC using Android Central Forums
Reply
