Bionic - Eclipse ROM 4G activation problem
bodaciousness
Hello Droid folks,
I picked up a Bionic, rooted and running Eclipse. Everything runs fine. Took it to VZ to service activated and somethings not right. The roaming triangle is flashing and I can't make calls or send SMS.
When I try to call I get a message about "If you would like to make a collect call...".
I do however get data just fine. I moved up from a Droid X (3G) to this phone which is 4G LTE. <-- Not sure if that's a factor.
Anyway, I'm thinking a factory reset might be in order but wanted to check with you experts and see what you thought. Let me know what you think.
THANKS
jesper76
