I've had this phone since mid-May. It's my first Android phone and I love it. Recently I started getting low memory warnings on it every few days or so. Following some suggestions I read on this forum, here's what I've done so far:
I plan to move a few apps to the SD card when that comes, but I've looked under Settings >> Applications >> Manage Applications >> All and there aren't that many apps I have the option to move.
Other than the apps that come installed on the phone, I've added the following:
(Gee, that list is longer than I thought.)
Short of deleting apps that I don't use super-frequently, is there anything I can do to improve memory usage? Quick Settings says I have only 13% free or 21.72MB.
- deleted text messages
- filed mail from my Gmail inbox, so the inbox is now empty
- deleted all but a few pictures that I rotate as my wallpaper
- ordered a larger SD card from a seller on Amazon (waiting for it to come in the mail)
- downloaded and installed Quick Settings app so I can see what's going on
- Quick Settings
- Carfax
- Google Maps
- Weather Channel
- GasBuddy
- Amazon
- eBay
- Barcode Scanner
- Random Mahjong
- Google+
- RingDroid
