Results 1 to 2 of 2
    Plow13's Avatar
    Posts
    Global Posts
    96 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Option for battery charger
    I am looking for battery charger that has the micro USB wire built-in and it's probably around 5000ma
    What do you recommend
    Sent from my SM-T310 using AC Forums mobile app
  2. #2
    qxr
    qxr is offline
    qxr's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Option for battery charger
    Try amazon for lots of options. One thread recommended the 9000 powergen with built in micro usb. I have the motorola 4000 but it isn't enough power for my needs.
  1. Hot Pot master is looking for hungry testers !
    By HotPotMaster in forum Developer Beta Testing
    Last Post: 08-02-2013, 05:29 AM
  2. Replies: 6
    Last Post: 07-13-2013, 03:29 PM
  3. Put battery in the Wrong way , now Mobile wont turn on !
    By Darkspliter in forum Sony Xperia P
    Last Post: 07-10-2013, 05:24 AM
  4. AndiOS7 - THE iOS7 theme for Android
    By bagarwa in forum Wallpapers, Ringtones, and Themes
    Last Post: 07-09-2013, 09:03 PM
