Results 1 to 3 of 3
    Default Does the charger adapter make a difference? Don't want to hurt my battery....
    I might be getting a charging dock, but i want to be able to put my phone on the dock without it always charging so I would get a usb charger adapter with an off/on button. Are all adapters the same, or some safer, or faster, slower, risky, what. Big tia.
    Looking at this one right now:
    http://www.meritline.com/showproduct...-switch-on-off
    And since i'm on the topic, what determines the speed of the charger, the amps? or the watts.
    update, so now i've come across this site, http://www.righto.com/2012/10/a-doze...-apple-is.htmland i guess cheapo usb power adapters are not the way to go. I could use my regular provided usb power adapter and add power extension with the scroll off/on switch, would that be safer? or would have it's own issues
  2. #2
    srkmagnus's Avatar
    Posts
    Global Posts
    7,292 Global Posts
    ROM
    Stock 4.4 (KitKat)
    Default Re: Does the charger adapter make a difference? Don't want to hurt my battery....
    OEMs always recommend the charger the device came with and/or OEM replacement. However, I think it's OK to go with reputable manufacturers and stay away from replacement chargers that are dirt cheap and/or unbranded. My opinion is to spend the extra money on something you know will be safe.
  3. #3
    Just got one for 15$ from eBay with NFC. S4 mini here
    Using Tapatalk
  1. Kogan android doesn't recognise my SIM card as 'local'
    By edfdave in forum General Help and How To
    Last Post: 12-16-2013, 02:21 AM
  2. Safe to update N4?
    By dazed_android in forum Android 4.4 KitKat
    Last Post: 11-24-2013, 12:10 AM
  3. Bluetooth makes keyboard glitch/unresponsive
    By sanssouci509 in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 11-23-2013, 10:03 PM
  4. Reset changed the language to Chinese
    By jehu01 in forum Samsung Galaxy Note 2 Rooting, ROMs, and Hacks
    Last Post: 11-23-2013, 11:08 AM
  5. Any free app/tool to tweak permissions in pre-4.3 environments?
    By Continuum88 in forum General Help and How To
    Last Post: 11-23-2013, 11:07 AM
B
