Results 1 to 2 of 2
    Default change battery
    Can bl-47th from lg g pro2 insert to lg g pro..
  2. #2
    Default Re: change battery
    take the two batts and compare the input and output voltages, then also check the amperes. If the numbers differ, then your shouldn't use it on the lg g pro. Usually if the voltage is lower, then your phone won't last long with a ful charge. If its higher, then you will be risking your device; later you might have to replace the power IC...I hope there will be no difference in voltage..
  1. Replies: 1
    Last Post: 09-01-2014, 01:20 PM
  2. Battery Pull (Automatically or Simultaneous)
    By WBSnow in forum Samsung Galaxy S5
    Last Post: 08-04-2014, 10:42 PM
  3. Replies: 1
    Last Post: 08-03-2014, 02:51 AM
  4. Battery temps under normal use?
    By mclasser in forum Google Nexus 5
    Last Post: 08-03-2014, 12:36 AM
  5. Replies: 1
    Last Post: 08-03-2014, 12:33 AM
