1. dpham00's Avatar
    Have a Verizon S8 or S8+, but using it on another carrier? If so then you know that Verizon loves to nag you about the fact that the SIM isn't from Verizon Wireless...No DUH! I know that already...no need to leave the constant nagging notification.
    So, I set out to find a way to get rid of this. First thing I did was to long press the notification to find out the offending app. Then I went to the app manager to disable it...oh but wait...Verizon in it's infinite wisdom made it so that the app can't be disabled from the app manager. Ugh. Typical Verizon.
    Good thing you can use Package Disabler to disable the app, and voila...no more nagging notification!
    If you need help setting up Package Disabler, then you can see my other guide:
    S8 & S8+: Disabling the Bixby app and physical button
    For those that want a free solution, you can use the XDA debloater tool to disable the same app, but keep in mind it requires a computer and is a little more complicated:
    https://forum.xda-developers.com/and...bloat-t2998294
    04-27-2017 10:38 AM
  2. marinoe's Avatar
    i need help, i put an att sim on vzw s8 and get this message, plus won't find signal!
    05-12-2017 06:55 PM
  1. Galaxy S8 Aux Cord Audio Feedback
    By AC Question in forum Samsung Galaxy S8 & S8+
    Last Post: 05-09-2017, 12:39 PM
  2. Replies: 1
    Last Post: 04-27-2017, 01:37 PM
  3. Replies: 1
    Last Post: 04-27-2017, 01:33 PM
  4. Can I change the color or contrast of the microphone dialog box?
    By Making progress in forum General Help and How To
    Last Post: 04-27-2017, 10:59 AM
  5. Lg G5 Not Charging from USB
    By creativus in forum LG G5
    Last Post: 04-27-2017, 10:01 AM
