Results 1 to 20 of 20
Like Tree1Likes
  • 1 Post By DroidXcon
    DroidXcon's Avatar
    Posts
    Global Posts
    11,639 Global Posts
    ROM
    Stock for now
    Default [How to] Fix unknown baseband, Radio/modem replacement
    Credit for this goes to over at XDA developers Forum
    So recently i decided to test some Odin packages i was experimenting with and as with any hack or modification there is a chance that something can go horribly wrong and it just so happened that it did. I somehow lost all signal to my phone and when i checked my baseband under settings>about phone it said UNKNOWN. I thought i was out of luck since no modem images are available for the Continuum as of now. Fortunatley there are people out there who are willing to think out of the box. trailblazer101 decided to flash the DL09 radio for the fascinate, AND IT WORKED!!!
    Then i decided if that worked there was no reason EB01 modem wouldnt work, so i tried it and sure enough , IT WORKED!!! So now im back up and running.
    So for whatever reason you lose your radio/modem on your phone download and use one of the following till an official one is released
    Modems
    Download DL09 from
    or
    Download EB01 from
    Flash either one of those using Odin if you need directions they can be found here: http://forum.androidcentral.com/599598-post4.html
    Thank you trailblazer101 for being exactly that a trailblazer
    If i've made life easier buy me a Macchiato
    Thanked by 4:
    elnetsh likes this.
  2. #2
    Default Re: [How to] Fix unknown baseband, Radio/modem replacement
    thanks
  3. #3
    Is this fix phone specific or will it work on a epic 4g touch as well?
  4. #4
    I got same problem but in Galaxy S2
    is there any chance to fix it???
  5. #5
    is it can work if i using CMD...my sgs ii cannot connect the pc with cable..
  6. #6
    wildman9904's Avatar
    Posts
    ROM
    What day of the week is i
    Default
    Here ismy suggestion. Hot up your respective forums. Anyone who has done a dump of your phone number ould have the modem file. As for a cwm version of it, that is simply a matter of update script. It wouldn't be too hard for a dev to package. You can try the modem on here, but I doubt it would work. For one thing, this modem is for a phone on Verizon. Neither the pic or sgs2 are Verizon phones. For that matter, most likely the sgs2 you have is on a gsm network, which is a totally different modem.
    Either let me fly or give me death. Let my soul rest, or take my breath. - DMX
  7. #7
    Appreciated buddy, my S2 finally works
  8. #8
    Posts
    ROM
    Default
    Quote Originally Posted by tstee3 View Post
    No problem
    I am not a fly, i am levitation. I represent an entire generation. - Niki Minaj
  9. #9
    gryncc's Avatar
    Posts
    ROM
    stock froyo
    Will this work on the g2x i have the same problem
  10. #10
    Posts
    ROM
    Default
    Quote Originally Posted by gryncc View Post
    Read up.
  11. #11
    hello
    i tried to to this using odion @ the modem slot , it keep giving Fail , my device is GS II and the Stock rom is JPKF3
  12. #12
    Posts
    ROM
    Default
    Quote Originally Posted by albloushi View Post
    hello
    What a surprise. It's a baseband for FASCINATE AND CONTINUUM!! These things are Not interchangeable.
  13. #13
    plz let me know if it worked with Lg G2x .
    I cant access the directions page .Plz help!
  14. #14
    Posts
    ROM
    I give up.
  15. #15
    Links dead!
  16. #16
    Posts
    ROM
    Default
    Quote Originally Posted by fa2ality View Post
    Links dead!
    Not surprising. Look at the age of the op. What phone do you have?
  17. #17
    Could you please Upload again that file? Thanks very Much.
  18. #18
    Quote Originally Posted by darck man View Post
    still having the same problem?? send me an email!! !! I might have the solution!!
  19. #19
    will this work with my xolo q800 ..???plz reply fast...
    n could u tell me the steps to follow in this method..
  20. #20
    please upload the file. the link is dead!
