Droid 2/droid 2 global case to fit car dock with extended battery?
compchick813
Active member
Sep 8, 2010
30
We just got my husband a droid 2 global (same size as droid 2) and we're trying to find a case that will fit the car dock with the extended battery. I have a Droid X with the extended battery, and I was unable to find a case to fit it with the car dock (I ended up getting a Zagg skin). I expect that we'll have to same issue with his phone. The D2 extended battery doesn't add too much thickness, but enough to make a difference with cases. We haven't gotten the car dock yet since I want to get it for him for xmas, so I want to make sure that the case he gets will fit it. Has anyone had any luck with a case for the D2/D2G with the extended battery and car dock?
dk21
79
3
You'll probably want to verify that the Droid 2 Global fits the Droid 2 car dock. I'm pretty sure the D2G has a lip of sorts at the top. It may or may not make a difference, but they aren't exactly the same size. Based on my car dock, I'd say the extended battery will cause problems.
