Results 1 to 5 of 5
    Default bootloader problem
    okay so on my droid 2 global im trying to sbf it and its not working. i have the rsdlit 4.9 download along with the VZW-4.5.608.zip but what ever i do to get past the flash non of it works and so now my phone is stuck at bootloader even when i take out my battery and put it back in. it willl just boot up bootloader.can anyone help? ill pay $10.00 paypal if some one can fix this
  2. #2
    scarryman04's Avatar
    Posts
    ROM
    Jelly Bean/ Thors ICS
    Default Re: bootloader problem
    You have to unzip the zip file and find the SBF file then when you start the flash in rsd you use the SBF file
  3. #3
    Kinglo's Avatar
    Posts
    ROM
    No more roms for me.
    your rsdlite version is around 2 years old. latest version at least 5.6
  4. #4
    Default
    After the flashing process was complete, and the phone was rebooted by rsd, did you hold down the physical x key?
    If not, just hold down that key on restart, then when the screen with the android and a "! " appears, push vol up and down simultaneously to enter stock recovery. Choose factory reset, run it, then choose reboot system.
    Tapped on my Bionic running KIN3TX.
  5. #5
    Posts
    ROM
    The version of the program shouldn't affect the outcome of the process, the old version is the only version I've ever used and its worked every time...
