Results 1 to 14 of 14
    corydunbar's Avatar
    Posts
    Carrier
    AOSP by preferance
    Default How to get even better call quality on the Droid 2
    This has been a post over in the Droid X forums for a while. But if you haven't already seen this, there is a way to increase call quality in our Droid 2 conversations. This site gives a very clear rundown of how to boost your call quality.
    Simple Droid X Hack Can Greatly Improve Call Quality | Techerator
    Note
    i have read over in the DX forums that this is not compatible with all ROMs. But it is compatible with at least stock, Liberty, and Fission. so that covers most of us.
  2. Thread Author  Thread Author    #2
    corydunbar's Avatar
    Posts
    Carrier
    AOSP by preferance
    Default
    has anyone else tried this on their Droid 2?
  3. #3
    Smitty_82's Avatar
    Android Addict
    Posts
    Global Posts
    1,597 Global Posts
    Carrier
    ICS / Stock
    Default
    Worked on my D2, didn't notice a huge difference right away. I'll have to test it more. The changes did take though and it worked on a test call after.
  4. #4
    Default
    When you say it is not compatible with all roms do you mean that there are some roms that just simply can't access the hidden menu? Or do you mean some people can go thru all the steps but it will just not work? Or would it even mess up the call quality altogether?
  5. #5
    dkear's Avatar
    Posts
    Global Posts
    131 Global Posts
    Carrier
    AOKP b38
    Default
    It worked for me. I haven't actually got on a call yet.
  6. #6
    Default
    What rom are you running dkear?
  7. #7
    Default
    I just did this and after the reboot i could not hear anything. Also the person on the otherside of the line could not hear me. I promptly reset my phone
    I have D2, liberty 1.5
  8. Thread Author  Thread Author    #8
    corydunbar's Avatar
    Posts
    Carrier
    AOSP by preferance
    Default
    it worked on fission 2.6.1 without any problems for me.
    corydunbar's Avatar
    Posts
    Carrier
    AOSP by preferance
    Default
    Quote Originally Posted by kwest12 View Post
    This is the exact same trick the Incredible users used and the Droid users used and probably users of other phones as well. Like the article says, you're simply changing the phone to use a newer type of voice codec.
    From what I've read about this, the only reason that phones don't come this way out of the box is b/c not EVERYWHERE supports this codec yet. If you happen to be in one of the few areas unlucky enough not to support this codec, just change it back if it doesn't work.
    AFIAK there is no downside do making this change if this codec is supported in your area (which it most likely is). I know the article says something about faster battery drain but I don't believe the Incredible users were reporting any increased battery drain after doing this either.
    I found this over on androidforums.com
  10. #10
    Default
    I did it about a week ago but I really haven't noticed much of a difference.
  11. #11
    dkear's Avatar
    Posts
    Global Posts
    131 Global Posts
    Carrier
    AOKP b38
    Default
    Quote Originally Posted by deadlybatman View Post
    Liberty 1.5
  12. #12
    phillyphreak's Avatar
    Posts
    Global Posts
    648 Global Posts
    Carrier
    leaked 2.3.3 rooted
    Default
    Options are different on Gingerbread. Anyone get this to work?
  13. #13
    Default
    The Vocode option is not available on my D2G through this method. Not sure what that means.
  14. Thread Author  Thread Author    #14
    corydunbar's Avatar
    Posts
    Carrier
    AOSP by preferance
    Default
    the droid 2 global may be different then. because it worked on my droid 2 and my droid x
