I have what could be a major problem, borne mostly from my stupidity and lack of forethought, but perhaps some of you will be kind enough to take pity and help me.
I recently rooted my D2, still well under contract with Verizon. Foolishly I decided to use my new found power to permanently remove some of the bloat-ware that came on the phone, including the Motoblur launcher. I didn't back any of these apps up, because I'm an idiot.
Now, my phone is having microphone issues, which I have come to find are relatively commonplace, and I am confident that Verizon will replace the phone if it's under warranty, but even though I have unrooted and performed a factory reset of the phone, some of the factory apps are still missing and I am worried this will cause warranty problems for me.
Is there a good way to get those apps back onto the phone, or perhaps even a list of the apps that come on a factory default D2?
