Page 1 of 2 12 LastLast
Results 1 to 25 of 41
Like Tree10Likes
    Grumple's Avatar
    Posts
    Global Posts
    40 Global Posts
    Default How much of a difference does .2 GHz make?
    I have been waiting for this or the GS2 to come out for months and I have been telling myself that I would only buy this if it has a 1.2 GHz processor because that would put it on par with the GS2. Obviously, I was a bit disappointed when they announced that it is just 1 GHz. But now I'm starting to wonder; is there really a big difference between the two? Would the GS2 be noticeably faster or not really?
    Thanks in advance for any help!
  2. #2
    Default Re: How much of a difference does .2 GHz make?
    A .2 GHz increase is really not going to make that much of a difference. Besides, once rooted you'd be able to overclock to 1.2 GHz or higher anyway. I wouldn't worry about the clock speed difference. Get the phone you like the most.
  3. #3
    SuperMarioVT's Avatar
    Posts
    ROM
    Bugless Beast -Jelly Bean
    +1 to mjforte's post bellow. I think people should stop worrying so much about the phone's specs and just play with it at one of the verizon stores and see if it they like or not.
    People should get the phone they like most.
  4. #4
    p08757's Avatar
    ** Superhero **
    Posts
    Global Posts
    1,914 Global Posts
    .2 would conceivably give you 20% more speed. I would take that bump any day.
  5. #5
    DolfanCole's Avatar
    Posts
    ROM
    CNA 3.0/leanKernel 4.2.0
    Faster clock speed allows for faster operations. But there are so many other factors that go into the "smoothness" of a device. So the answer to the question is, it depends.
  6. #6
    Paul627g's Avatar
    Posts
    Global Posts
    13,749 Global Posts
    ROM
    Milestone 1/Lean Kernel
    I honestly don't believe any of the newer dual cores and quad cores will truly show their full potiental for some time to come. Until developers and the apps they create incorporate the code to take advantage of these newer processors and their abilities its just a "status" thing.
    Given time they will be impressive but at this point I think the developers still have some catching up to do with the technology that is being provided.
    Just my thoughts, but normally I believe any new technology/devices take a good 6 months or so on the market to really be appreciated by the developers and coders.
    Thanked by 2:
    Preach2k, Mooem and trailblazen like this.
  7. #7
    redraider133's Avatar
    Banned
    Posts
    Global Posts
    1,373 Global Posts
    Quote Originally Posted by mjforte View Post
    Well if they don't get the bootloader unlocked then there will be no overclocking since you will have to use the stock kernel. But .2ghz shouldn't make a difference the only difference will be how optimized the interface is compared to the other(blur vs touchwiz)
  8. #8
    ragnarokx's Avatar
    Posts
    Global Posts
    8,669 Global Posts
    ROM
    SlimBean, LiquidSmooth
    Default
    Quote Originally Posted by redraider133 View Post
    Weren't the Moto guys able to overclock with a locked bootloader on the X?
    Sent from my Nexus S
  9. #9
    Quote Originally Posted by ragnarokx View Post
    I may just be being ignorant, but i've got an overclocking widget on my OG Droid that is not a kernel change, its just software that runs while rooted and i choose to turn it 'up' if i'm about to overload things by playing Robo Defense I bump it up to 800 from 550 while playing.
    I am Running Cyanogenmod and obviously the OG Droid has an unlocked bootloader, but i am not so sure that has anything to do with the ability to Overclock the way I am.
  10. #10
    moosc's Avatar
    Grand Master Moosc
    Posts
    Global Posts
    5,019 Global Posts
    ROM
    AKOP M4 old geezer theme
    Default
    Not true the X is locked and it go overclocked to 1.5 . U just can't swap kernals with a locked bootloader.
  11. #11
    moosc's Avatar
    Grand Master Moosc
    Posts
    Global Posts
    5,019 Global Posts
    ROM
    Default
    Yes we can overclock with locked bootloader I'm running 1.5 ghz
    Thanked by:
  12. #12
    1.2 ghz dual core would actually be 0.2+0.2 making it 0.4 ghz faster 0.4 ghz is a nice bump from a regular 1.0 dual core.
    Don't forget the nice AMOLED screen and better front facing camera.
    Bionic no doubt will be a nice phone but Moto dropped the ball... Unless it comes out with real world-wide phone capabilities it just doesn't stand up spec wise to the GS2.
  13. #13
    Quote Originally Posted by xjoshuax89 View Post
    1.2 ghz dual core would actually be 0.2+0.2 making it 0.4 ghz faster 0.4 ghz is a nice bump from a regular 1.0 dual core...
    Simple math like this for processor speed of multi-core processors is misleading and does not really give an accurate picture of the possible improvement in performance for a given device.
    There are WAY too many variables here to give any kind of accurate prediction as to how the Bionic's OMAP 4430 processor running at 1 GHz will perform against the GS2's Exynos processor running at 1.2 GHz.
    Thanked by:
  14. #14
    phone will run the same as the droid 3, its the same processor
    droid 3 without a keyboard but with LTE and bigger screen and some more RAM
  15. #15
    Don't forget the nice AMOLED screen .
    Have fun with your overblown/oversaturated un-natural colors!
    I had a charge and was not happy with how overdone the colors were with the AMOLED. Like they took a big box of crayons and used the most outrageous colors that no one ever uses for the color pallet.
    I'd bet Cory's Right Arm on that!
    -Grandfathered Unlimited-
    tdizzel and ChevyNovaLN like this.
  16. #16
    Quote Originally Posted by demarco5 View Post
    Just because the phone has the same processor doesn't mean it will run the same.
    Also, you left out LTE and WebTop. So basically a Droid 3 if i were to put "not a" in front of that statement. Same processor but with upgraded RAM, upgraded screen size (if you're into that kind of thing), more features and upgraded data speeds.... sounds like an upgrade to me.
  17. #17
    That's the point - it will NOT work like a D3 for the very reasons you listed...it does have the same processor, but with 1 meg of RAM, hopefully it will run even better; faster, smoother, etc. But with LTE and the larger screen, those could slow it down. The point is, we won't know how the Bionic will perform until we see it in action. 1 or 1.2, there are just too many other design features that affect performance.
    Cory
  18. #18
    same processor though, RAM will make a difference but nothing crazy
    i think it has the same camera as the droid 3 though which is a downfall because all the reviews are killing the problems with the droid 3 camera
  19. #19
    Pratt4321's Avatar
    Posts
    ROM
    CM 7 with Chevys LV 1GHz
    Quote Originally Posted by corymcnutt View Post
    I sure hope it isnt 1 meg
  20. #20
    not saying i wont buy it, i probably will because it should be the best phone (4g and spec wise) on verizon until the end of this year....i just hope i can type as fast on the touch screen as ive done on the og droid qwerty
  21. #21
    Quote Originally Posted by Pratt4321 View Post
    LMAO! You got that right, sorry!
    Cory
  22. #22
    Default
    I thought I would miss my QWERTY keyboard when I got the Thunderbolt but having a bigger screen definitely makes it easier to type on.
  23. #23
    i know but i txt at least 50-100 messages a day i just hope the speed is there
  24. #24
    Default
    I'm not sure if you have an OG Droid now or not, but I suggest trying out a few keyboards on the market and try getting used to a virtual keyboard. Takes a period of adjustment, but you'll probably be typing just as fast in a few weeks.
    Sent from my Droid using Tapatalk
  25. #25
    srkmagnus's Avatar
    Posts
    ROM
    Calkulin 2.7/Desperado
    Default
    I agree with irl Panda, use other keyboards from the market and your sure to find one that suits your typing style. I use SwiftKey and its great, accurate and efficient.
    Sent from my wildheroc using Tapatalk
