FM Radio not on phone
jax_droid
Active member
Apr 5, 2011
44
6
WAsnt sure if the Bionic was going to have it- multiple reports said it would. Well it's not there in the app tray but if watch the help videos that are on the phone itself, it shows FM radio as part of it. So, the instructional videos that are shown must not be the bionic, right?
GBH2
206
53
in the bworley "My Bionic" Thread it was stated that Bionic has the functionality, just needs an "app". Someone posted an FM radio .apk , bworley said he downloaded and installed it and it worked and gave hime FM radio functionality on his Bionic. Just try searching that thread - if you have any problems finding it let me know - I downloaded the .apk when it was posted, although I haven't tried it yet.
Reactions: jax_droid and jroc
ChevyNovaLN
598
57
www.ChevyNovaLN.com
Here it is guys, I looked too :)
FMRadio.apk
UPDATED URL: http://www.chevynovaln.com/files/APK/FMRadio.apk
( Looks like Mediafire.com pulled the file due to 'violation'. Ok then... well, here's my copy i'll host unless i'm told to stop as well.)
It does work, though it has a requirement that you have a headphone jack (or speaker, etc..) plugged into the jack on the top of the phone for it to even launch the app. I had an old cable that I didn't need so I cut it just past the jack and used that and the FM Radio app pulls up and will play audio via the rear speaker if you tell it to. You will NOT be able to use bluetooth headphones with it, however, due to having the headphone jack in use. It always takes precedence. So if you have a set of wired headphones or want it to play via 'speakerphone', it works great :)
I can host the file on my site too if anyone has trouble with mediafire, but I will not do that unless you've at LEAST tried getting it there first.
ChevyNovaLN
598
57
www.ChevyNovaLN.com
What is FM radio?
Its literally an FM Radio... yanno.. like the one on the 'radio' in your car? :) Unless you listen to AM Radio.... but FM is most likely it. hehe
Ok... in all seriousness. This is pretty cool. Install the app and plug some headphones in before you launch it. you can get your favorite radio station 'over the air', its not something that uses data, etc.... its just plain 'ol radio waves.
EDIT: I'm 'fairly' sure it doesn't use any data. I put my phone in Airplane Mode and then it told me i had to take it out of airplane mode to use FM Radio. Odd.
trailblazen
789
84
Works......... LIKE A CHAMP! Thanks for the apk.
One thing I did notice is it does not like the audio plug on the docks.. Looks like it needs a direct headset connect to the phone for the app to work.
xjoshuax89
79
8
bah I wish they would remove the audio jack must have the headphone/earphone w.e. inserted to launch the app. So annoying...
trailblazen
789
84
That is exactly what I did using the same type of cable. I just cut 1 end of and it just sticks out of the top of my phone for about an inch
Sent from my DROID BIONIC using Tapatalk
Eww i didn't cut anything, just left it twisty tied. Left it in the dock listening to my local radio station while cooking dinner and it doesn't bother me having all that hang off. Besides, not trying to win any beauty contests at home and if im at work im headset on anyway LOL.
moosc
Grand Master Moosc
Oct 20, 2009
3,264
162
I can't tell u last time I listened to FM it just sucks. Its satellite radio and internet. And I can use my BT speakers
Gekko
Banned
May 15, 2010
5,263
123
fyi - i installed this apk on my EVO just for ****s and giggles. as i suspected - it does not work. the HTC FM Radio App looks better anyway.
fogflyer
89
10
I headphone is probably required to be plugged in because FM radios require an antenna and it is probably using the headphone cable as the antenna. Are those of you putting a small patch cord in there getting decent reception?
fogflyer
89
10
Just downloaded it and it works great.:)
Why do you suppose Motorola (or Verizon) would have disabled this function after actually putting the hardware in to do it?
Laila Nance
