- 09-22-2011, 11:24 AM
Thread Author #1
- 09-22-2011, 11:37 AM #2
Return it.
Sorry but I had to post that. I gave up because I was at the end of my 14 days. I hope you all can find the magic bullet or the battery life Holy grail.
Sent from my DROIDX using Tapatalk - 09-22-2011, 12:18 PM #3
Re: battery tips for the bionic
I'm rooted and froze the recommended apps (mostly Verizon bloat) in the rooting thread. I unplug at 7AM and around midnight I have 30% to 50% left using the extended battery. That's more than good enough for me.
Semper Fi
I love my LG Nexus 4! - 09-22-2011, 12:22 PM #4
- 09-22-2011, 12:33 PM #5
Get an app. like Juice Defender. It has supposedly increased my battery life by x1.40.
Go into Task Manager and setup your auto-end list. I have things like Maps, slacker, social location, vz navigator, google+, facebook on my list. 2 minutes after your screen goes off those apps will be killed.
Turn your brightness down as low as possible while still being able to comfortably see the screen.
Avoid using Active Wallpapers.
Turn off 4G when not using it. Go into Wireless & Network Settings > Mobile Network > Network Mode and select CDMA only.Last edited by mbentley3; 09-22-2011 at 12:40 PM.
- 09-22-2011, 12:37 PM #6
I noticed that Bluetooth used a large portion of my battery (based on 'usage statistics' in settings). I only use Bluetooth to stream to my car stereo so I use the app 'Settings Profile' to turn on Bluetooth automatically when the phone is in the car dock and it turns off when I remove it. Love that app.
- 09-22-2011, 01:30 PM #7
My OG droid came with a power widget so you can easily turn bluetooth and GPS off/on. I have the widget on my second screen to the left. Does this thing come with a power widget?
Facebook - if you never go into Facebook on the phone will this app just start every time and begin this social location crap? - 09-22-2011, 01:31 PM
Thread Author #8
- 09-22-2011, 01:35 PM #9
- 09-22-2011, 01:41 PM #10
My battery life is between 8-16 hours on the standard battery depending on my usage. I am in 4g most of the day.
- 09-22-2011, 01:55 PM #11
- 09-22-2011, 02:49 PM #12
- 09-22-2011, 04:48 PM #13
I am rooted and removed pretty much all bloat (froze and moved to SD card) and I can finish my day from start to finish with some battery life remaining. Plug my phone in over night and start over the next day. Key is to keep off connections that aren't used (WiFi, Bluetooth, GPS). Yea I can drain my battery pretty damn quick if I play with it straight for an hour but generally I can get a full day. Longest time I have had was about 28.5 hours.
- 09-22-2011, 04:50 PM #14
- 09-22-2011, 04:51 PM #15***GET IN WHERE YOU FIT IN***
Snitches get stitches
Boneyard-D1,Dinc,dX,Gtab7",Tbolt,iPad1,Bionic,Xoom,iPad2,Charge,GNexus,SGS3,Razr Maxx,Nexus7...the list shall continue
Living Dead-iPad3,GalaxyNexus,Razr MaxxHD - 09-22-2011, 05:00 PM #16
- 09-22-2011, 05:06 PM #17
Honestly its not that bad advice to return it. If someone can't stand the battery life then why keep it and waste an upgrade especially for a $300 upgrade phone. Personally I believe that if you buy an Android phone and expect good battery life, doesn't matter what model, you are naive. Don't believe what manufacturers will tell you or Verizon themselves about battery life. Everyone will experience different battery life depending on use.
That is why Verizon has a 14 day period you can return. Out of every Android phone I have had the battery life has been from pitiful to okay only. If you don't want to add bulk with an extended battery then you need to live with the fact, at least for now, that battery life will not the star feature of this phone or any Droid phone in general.
I don't want to come off as a **** but every reviewer views battery life as a negative, its just the degree as to how bad. What phone are they comparing it to? Of course the iPhone which I can personally attest to has great battery life for a smartphone. However that comes with a trade off, you don't get the power and capabilities of the Android OS. - 09-22-2011, 06:02 PM #18
- 09-22-2011, 06:08 PM #19
- 09-22-2011, 06:09 PM
Thread Author #20
I hear what i are saying but this is not an instnce like that. Im cool with my battery life especially since its 4g. Im asking everyone hear to sjare the tips or tricks to conserve life to see if i missed something or for anyone else. Saying return it is just the usual immature response you will get from time to time on these forums. If peole would read the post they would know im just simply asking people to participate in some tips as i did.Thanked by 4: - 09-22-2011, 06:14 PM #21
Tip #1: Extended battery.
Tip #2: Make sure email ect is set to a longer update rate. I use an hour. You can manual update any time you need to.
Tip #3: Charge whenever you can.
Also remember this. People don't buy a high end exotic sports car and then whine about fuel economy. If you want a phone that lasts days and days get a jitterbug. IMHO - 09-22-2011, 06:32 PM #22
- 09-22-2011, 06:35 PM #23
- 09-22-2011, 08:00 PM #24
the sports car isn't bad on gas, the escalade is. Not trying to be a jerk here but I did try to get make this phone work. If it can ever make a day on a charge I will get it again. I should also apologize, my first post was meant to be tongue in cheek and not nasty. The only reason I returned the Bionic is the 14 day costco limit, if the limit was 30 days I would still be trying to work through this. I just ran out of time.
Sent from my DROIDX using Tapatalk - 09-22-2011, 09:39 PM #25
Reply
