1. 1812dave's Avatar
    on the extended and the stock battery? I just got my first extended battery today and it's having a bit of trouble getting the voltage up above 4 volts. I left it in the battery charging dock for an hour past when I saw the indicator lamp turn green. put it in the phone and immediately got a "90%" indication of battery level. charging it now inside the phone and got it to read 100% in a short time, but terminal voltage isn't as high as the stock batteries (I have 2 of them).
    Is anyone getting over 4.125 volts?
    09-22-2011 07:47 PM
  2. JCHoefer's Avatar
    Battery Indicator Pro shows 4.344v in the logs as the highest. 100% charge looks to be always about 4.3 volts.
    Sorry....standard battery.
    1812dave likes this.
    09-22-2011 07:51 PM
  3. 1812dave's Avatar
    my extended has been stuck on 4.065 for over a 1/2 hour, after I got the 100% indication on the phone (it went from 90% to 100% way quicker than I thought, but I'm concerned about the max voltage being a bit low).
    I'm using a USB charger that's a bit more than 1 amp. the stock charger is around .850
    09-22-2011 07:55 PM
  4. pwscott's Avatar
    Where are you seeing a voltage reading? In an app or widget it....?
    Sent from my DROID BIONIC using Tapatalk
    09-22-2011 08:35 PM
  5. 1812dave's Avatar
    it's a widget, called Battery Indicator. it shows the battery level in the notification area.
    09-22-2011 09:02 PM
  6. pwscott's Avatar
    Thanks....already use that, just never noticed the voltage reading.
    09-23-2011 08:15 AM
  7. 1812dave's Avatar
    I found out this morning that the battery dock isn't fully charging any of my batteries (I've had 4 of them, including one replacement std battery). I'm taking it back to verizon today to exchange it. if the next battery dock does no better, I'll get a refund.
    Yesterday was the first time I used the extended battery--it was only charged to 90% via the battery dock. I had to finish charging it in the phone. Last night I put the extended battery (depleted) into the battery dock at 8PM. this morning at 6AM the green light was on, I put it back in the phone...shows just 90% charge and a voltage of 4.04 volts.
    09-24-2011 08:28 AM
