Results 1 to 5 of 5
    IRSmurf's Avatar
    Posts
    ROM
    Stock
    Default Stuttering audio over A2DP Bluetooth?
    Good evening,
    While walking, tonight, I paired my Plantronic Voyager 855's to my Bionic for the first time. My thirty minute phone call was flawless. The music I streamed afterwards was not.
    The audio suffered periodic stutters that sounded like a buffering issue. The audio was clear, but paused every couple seconds and resumed immediately where it left off.
    I did not experience this problem with my Garminfone, Nexus One, HTC HD7, Dell Venue Pro, iPhone 4, or any other handset or laptop before Bionic while using this same headset.
    What is your experience with stereo Bluetooth on Droid Bionic? Please post your headset model with your description.
    Thank you for your participation.
    Sent from my DROID BIONIC using Tapatalk
  2. #2
    brandonx1000's Avatar
    rule the air.
    Posts
    Global Posts
    1,031 Global Posts
    Default
    No issues while using my jabra stone2 or Plantronics votager pro+...streamed a bunch of music through Google music with no stuttering
    Sent from my Xoom using Tapatalk
  3. #3
    Default Re: Stuttering audio over A2DP Bluetooth?
    I have the same issue with sync in my ford..
    Any ideas?
  4. #4
    Quote Originally Posted by randyd8511 View Post
    Any ideas?
    I've experienced this using the Ford Sync with my OG Droid and my Bionic. Turning the wifi off fixed the problem for me.
  5. #5
    Default
    You nailed it Jordo!
    Worked like a charm on mr Droid Bionic w/ Ford SYNC.
    THANKS!
