Battery dock not fully charging batteries
1812dave
3,133
35
I got the battery dock on launch day and have used it some of the time, to charge my batteries. A couple days ago I bought the extended battery (at the same time I exchanged one of the std batteries that I felt was defective). turns out, the battery dock isn't fully charging any of the batteries. the extended battery won't charge past 90% no matter how long I leave it in the dock. I have to finish charging it in the phone. Also, the standard batteries aren't being fully charged either.
Anyone else having this issue? I hope a replacement dock (I'm going to verizon in a couple of hours to exchange) will work better.
zmann
3,306
120
I am having similar issue. I know it's a different phone. Bought dock 3 months ago but using spare battery charging slot for first time. Neither my stock or extended will charge if battery is at 80 percent or higher.
EVO-LUTION 3D
LrdAnkh#AC
49
YOu should not be charging the battery if it is at 80%, I typically run the battery down to 5% then put it to chrge and it charges 100% both the standard and the extended.
corymcnutt
615
37
That's not what Dave (please forgive me for speaking for you, but I know you well enough) was saying. He is stating that when his battery needs charging and he puts it in his charger, it will not charge it past the 90% level...it never gets to 100%.
kca2000
696
147
I had this issue too while i had my phone and 2nd battery w/ charger.
To remedy the issue i would pull the battery off the charger when the light went green(Full charge?). Wait 15 seconds, put the battery back on the charger and it would charge another hour usually. Seemed to work. Just like topping off a battery on my D1 charger.
1812dave
3,133
35
got the replacement battery dock. happy to report initial testing shows it's working better than my first one. I topped off a std battery and installed it in the phone. voltage is holding at 4.293--the highest I've ever gotten. I'm now charging one of my extended batteries (it was 80% when I took it out of the phone a few hours ago) and will wait til the light turns green and give it another hour. then I'll install it in the phone and see if voltage is as high as for the standard battery that I just charged on the new charger.
EDIT: no joy charging the extended battery. see post below.
1812dave
3,133
35
absolutely correct, Cory! The issue is present when charging a battery that has less than 5% charge...or any other charge level.
1812dave
3,133
35
while that's a good suggestion, it isn't a viable option when one wakes up in the morning with a battery supposedly fully charged in the dock, wanting to quickly pop it into the phone, and leave for the day. if one has time to fiddle with reseating the battery, then that would be fine.
kca2000
696
147
Yeah i can understand that. I found this work around because i was not 100% sure i would keep the phone. I agree exchanging it is the way to go. Would have done the same if i had kept the phone past the 14 day mark. Glad to see the new one is working out better.
Reactions: 1812dave
1812dave
3,133
35
Using the replacement battery dock, the extended battery won't charge over 70%. I've tried 3 times today. the light is amber for at least a 1/2 hour. eventually it turns green. put batt in phone--shows 70%. WTH??? this is worse than the first charger. also, I noticed that ext batteries are 3.7 volts, while the std batts are labelled as 3.8 volts. odd.
Travisimo
158
This may be a long shot, but are you certain that it's not a battery reporting issue? Have you tried either rebooting the phone again or testing how long the battery lasts when you do a swap? I know when I was swapping between my stock battery and the extended battery, the battery reporting seemed to get funky sometimes (inaccurate readings, etc).
1812dave
3,133
35
the second dock charged a brand new extended battery to only 90% after more than 9 hours. I put that battery in my Bionic and let the bionic charge it the rest of the way, which took less than 18 minutes. I'm taking the battery dock back for refund today. I'm tired of this poor performance. I can only get the batteries to charge properly inside the Bionic.
1812dave
3,133
35
I've had FIVE batteries, TWO docks, and 17 days to try this all out. Many reboots, battery pulls with power ON. it's NOT the reporting--it's the level of charge thru the dock that is at fault.
EDIT: I was first in line at Verizon today--returned the dock for refund. Problem solved.
