Results 1 to 8 of 8
    Default No sound
    I've had my Bionic for a couple weeks. After a couple days, it appeared to have lost its audible sound capability. No rings, no notifications. I've been setting up a lot of things, but I can't imagine how I might have turned it off. I've searched through the 'sounds' section of 'settings'. I've got sound turned on at the 'unlock' screen. Has anyone else had this problem? Does anyone know of any obscure, hidden ways you can turn sound off?
  2. #2
    Default Re: No sound
    Under "sound" do you have SILENT MODE checked off? Look under VOLUME also and make sure the volumes are up? Interesting...
    Cory
    Silent mode is unchecked and volumes are up.
  4. #4
    Sorry, I figured as much, but sometimes we forget the obvious! Did you try a battery pull?
    Cory
    Do you mean removing and re-installing the battery? Yes, I tried it (because of a lock-up).
  6. #6
    Quote Originally Posted by dhunter7 View Post
    The same thing happen to me last night around 2AM. I woke up and grabbed my phone everything was working fine. Maybe the night mode turns off all the sounds or the battery saver...???
    I accidentally dropped my phone the other day, and I got the sound back. There must be a loose connection.
  8. #8
    Default
    Have u tried master reset let verizon know that way moto can fix with update un nov. Mine does it once in a while the vol will go lowwwww then master reset and its copastetic
    Sent from my DROID BIONIC using Tapatalk
