Android Forums at AndroidCentral.com >  Verizon Droid Forums >  Droid Bionic > In call volume
In call volume
Reply
Thread Tools Search this Thread
    Thread Author   #1
Old 09-28-2011, 12:21 AM
Activity: 0/20
Has anyone realized you can't change the in call volume while the phone is at your ear? I need to take it away and have the phone light up for me to change the volume.
Isolated or standard?
Sent from my DROID BIONIC using Tapatalk
  #2
Old 09-28-2011, 12:39 AM
Device(s): Droid X and Xoom
Activity: 1/20
Works on mine. But it adjusts very slowly.
  #3
Old 09-30-2011, 06:15 AM
Device(s): Driod Bionic
Activity: 0/20
I can adjust mine while using it. Takes a little bit for it to increase/decrease tho.
  #4
Old 09-30-2011, 08:32 AM
Activity: 3/20
It might have something to do with the settings, I believe there is a check box for the rocker to be disabled when the screen is off. Which is nice when the phone is not in use to avoid volume changes, but dumb if it also affects it while in call.
    Thread Author   #5
Old 09-30-2011, 11:14 AM
Activity: 0/20
it sounds like it should be right. I cannot find it. If you do let me know please.
  #6
Old 09-30-2011, 02:00 PM
Activity: 1/20
Have you tried hitting the rocker multiple times or just once and hold?
    Thread Author   #7
Old 10-11-2011, 11:33 PM
Activity: 0/20
Both. Its begining to get irritating
  #8
Old 10-12-2011, 01:26 AM
Device(s): Bionic
My Next Device: Something in 05/2013
Activity: 2/20
Same issue here can't find any settings for it
  #9
Old 10-13-2011, 04:47 AM
Device(s): OG Droid, Droid X, TBolt
Activity: 0/20
This has actually been a thing with all android phones I have owned.. dx/og Droid/thunderbolt/bionic. Really annoying.
EDIT: I just tried it again and it does raise/lower with a multiple click method. Just holding it does not seem to do the trick. Funny because I thought I had tried that a few times and figured it was like all my previous owned phones.
    Thread Author   #10
Old 10-13-2011, 01:59 PM
Activity: 0/20
I found that I can adjust it in the very beginning of the call but not after
Reply
Search this Thread:
Advanced Search
