Results 1 to 25 of 25
Like Tree3Likes
  • 2 Post By 1812dave
  • 1 Post By EnergyPlus
    Default Is the power button terrible on purpose?
    Can Motorola really be that dumb to put a power button so chinzy that it feels like it's going to break every time you power the device on?
    the power button wobbles on each side unless you press directly in the center.. this is just rediculous! Does Motorola not have a QA department?
    Does anyone else baby their power button?
    Possible Errors Between Keyboard And Chair.
  2. #2
    Default Re: Is the power button terrible on purpose?
    i've no idea what u are talking about. the button works and feels fine.
    Thanked by:
    p08757 and corymcnutt like this.
  3. #3
    My power button is solid. I press it the same as I press any other button on any other device. No wobble...just a button.
    There's a new phone with a 10 GHz Octo-core processor with a 5.4" 1080p display that's coming out 3 months after you buy your next phone.
  4. #4
    Yep, fine here too. It's always better to ask "is anyone else experiencing this?" before jumping in with accusations and looking silly.
    Sent from my Acer Iconia A500 or Motorola Bionic
    KoukiFC3S likes this.
  5. #5
    Default
    Solid button for me. Even through a silicone case.
  6. #6
    IRSmurf's Avatar
    Posts
    ROM
    Stock
    Default
    It's not as firm as the power switch on my ASUS EP121 slate, but my Bionic certainly has no wobble.
    Sent from my DROID BIONIC using Tapatalk
  7. #7
    Default
    Quote Originally Posted by IRSmurf View Post
    Mine actually just came off, not happy. A pin will turn it on but I'm not looking forward to swapping it out.
  8. #8
    Mine is solid too, no rock at all.
  9. #9
    Yeah mine's good too. I like it much better than the Thunderbolt's power button.
  10. #10
    I noticed the same thing mine jiggles as well. But I have a good phone and dont want to risk getting another one. I have an otterbox on now so I dont notice any more
  11. #11
    Mine is solid, no wiggle, works great!
    Cory
  12. Thread Author  Thread Author    #12
    Mine wobbles as if it's teetering on the actual button in the center. I only mention it because I also have an Iphone 4 which the power button feels like a damn solid brick when i press it, not my Bionic, it wobbles.
    So you all with solid buttons, if you're looking at the screen, can you press the right side of the power button to get it to turn on? or does it press down and "wobble"
  13. #13
    SSHGuru's Avatar
    Banned
    Posts
    Global Posts
    662 Global Posts
    ROM
    Lithium
    I can press to the right, in the middle or to the left and it works.
    The only thing I don't like is when I take it out of the dock in the morning I always hit it.
  14. #14
    I can press the right, left, middle, front or back and they all are rock solid
  15. #15
    Default
    Solid for me too.
  16. #16
    Default
    Not solid for me it my brother. I kind of bugs me. I hope I don't have to get another over a power button.
  17. #17
    The power button is solid on mine, just on the wrong side!
  18. #18
    andre2p's Avatar
    Posts
    ROM
    BB
    Mine wobbles too. You have to push it dead center or nothing happens.
  19. #19
    Mine seems to be rock solid. I like the feel of the switch on mine.
  20. #20
    kuyawil's Avatar
    Posts
    Global Posts
    7 Global Posts
    Default
    Mine works solidly, left, middle right....
  21. #21
    p08757's Avatar
    ** Superhero **
    Posts
    Global Posts
    1,916 Global Posts
    Mine is solid as a rock. No problems with mine.
    I typically find the build quality of my Motorola devices to be A++
  22. Thread Author  Thread Author    #22
    Quote Originally Posted by p08757 View Post
    Me too, which is what I don't get.. there has to be a reason for this, maybe different manufacturing plants?
    If I'm staring at the phone, the button is sort of solid on the left, solid in the middle and if I press on the right, it completely sinks in and does nothing.
  23. #23
    IRSmurf's Avatar
    Posts
    ROM
    Stock
    Default
    Quote Originally Posted by sniffs View Post
    I'd never pushed on the right side of the switch before. Pushing the left side gives the nice click feedback, but pressing the right side makes my switch sink, too. (But it still activates the switch.)
    Meh. As long as it works for me, I'm satisfied. If yours sinks but doesn't activate the screen, I'd take it to Verizon right away. The longer you wait, the more likely they are to tell you it's normal wear and tear.
  24. #24
    Arelunde's Avatar
    TECHFAN
    Posts
    Global Posts
    1,528 Global Posts
    No problems with my power switch either. Works fine and seems stable. Maybe you need to exchange your Bionic. It's early enough that you would likely get a new one rather than a refurb if you wait.
    Always learning ...
  25. #25
    There are apps you can use to power your phone down. One of them, "Fix Power Button", will even let you turn the phone on with the volume keys and turn it off with a widget.
    Good luck.
