No System Sounds through Bluetooth!
exostratics
Hey all, I'm new here, hoping I can get a little help about this problem...
I don't hear system sounds through bluetooth. For example:
I'm at the gym with bluetooth headset connect listening to spotify. If I receive a txt, or am using mapmyrun or anything, any other sound won't come through the headset, just the music. Is this normal? Is there a correction for this? It will pause the music and play the sound out of the headset though and start right back up.
Any help would be appreciated.
Always been the case...even on my old Droid. Not sure if there is anyway to fix this..seems to be part of Android.
yeah, ive had the same issue with my droid og, droidx, and bionic. it will mute the music when a notification comes through. ive also had that happen with the iphone, but with OS updates its worked. Maybe an android thing.
Aguswibowo
