Results 1 to 7 of 7
    huthjustih's Avatar
    Posts
    ROM
    AOKP B38, B40, and 4.1
    Default Shutter sound file location
    Does anyone have any clue where I can locate the shutter sound file location. I've tried the silent apps, app settings, ringer media and notification volume. Nothing works, and I want it gone! Any info or help would be great, thanks all!
  2. #2
    Default Re: Shutter sound file location
    If you want the camera not to have the shutter sound you can select shutter tone in settings and turn it off.
    huthjustih's Avatar
    Posts
    ROM
    sorry let me rephrase the question. Does anyone know where stock sound files are located so I can delete/change them. ie pathing
  4. #4
    I'm not sure if it's the same on this phone - I'm not rooted - but on my last phone it was /system/media/audio/ui. I think it's the one called "camera_click.ogg". I see that file there in Astro.
    Thanked by:
  5. #5
    Averix's Avatar
    Posts
    ROM
    Stock on most
    Why do you want to "repath" a file you can mute in the settings?
  6. #6
    EDNYLaw's Avatar
    Posts
    ROM
    AXIOM SHO V9 Franco R85
    /system/media/audio/ui I think, it might be in another directory under audio but I believe it's in ui. Just remember to change the permissions on the file (I use root explorer) to match the rest. Reboot and enjoy!
    Thanked by:
  7. #7
    rbeavers's Avatar
    Posts
    ROM
    Stock, Rooted.
    You need "Enforced Stream Silencer", sorry I don't remember where I got it.
    Quote Originally Posted by huthjustih View Post
