1. SirGeorgeKillian's Avatar
    3 bars of LTE and keep getting messages that the message didn't go through. Using stock messaging app, any suggestions?
    Sent from my DROID BIONIC using Tapatalk
    10-27-2011 03:51 PM
  2. Fable's Avatar
    Is it just texts? Are you losing all data services during that time? Is the up and down arrows on the 4G stuck on or not moving/highlighting at all?
    The current build (886) of the bionic has a radio drop/lock issue. When it happens again. Go to settings and put the phone in airplane mode, then in about 60 secs, take it out of that mode and see if the texts can be sent. Just an idea though, not sure if it's related.
    10-27-2011 04:33 PM
  3. SirGeorgeKillian's Avatar
    I literary typed that post as it was telling me message not sent. I browsed around a little, data was going through. The message never sent, i deleted it and reset the phone so it would quit notifying me....
    10-27-2011 10:43 PM
  4. tony bag o donuts's Avatar
    That's what you have to do.
    Otherwise it's stuck in sms pergatory.
    Delete the messages, reboot and it should always fix the issue.
    10-27-2011 10:55 PM
  5. Arelunde's Avatar
    I had that problem once and discovered the recipient wasn't subscribed to text messaging. The texts died on my phone - never sent. Got same message as you. Seems odd these days to find people who DON'T have texting capabilities, but therre are probably more than we know. Just sayin'...
    10-28-2011 09:21 AM
  6. SirGeorgeKillian's Avatar
    No, these were to other Droids and to iPhone users. I know they all have texting, I was texting them fine last week before I switched to this phone. I have been having problems damn near anytime I try to send one.
    10-28-2011 11:56 AM
  7. Arelunde's Avatar
    I don't know if this will help because it seems there are some tech issues at work. However, it might be worth a try...
    Download SMS Popup from market. I've used this on the Droid X And now the Bionic. Not a fancy app, but very customizable. Main purpose to put incoming text message over lock screen in popup box where you can reply, ignore or delete right there. Can individualize notifications, too, and LED colors. This app might take over your SMS and it might be better ... Or not. But maybe worth a try..
    10-28-2011 11:11 PM
