Random Freeze/Battery Drain
APeX3181
128
I installed the update two days ago, and unfortunately some issues still persist.
1. I lost data connection yesterday and had to switch to airplane mode to get it back. This morning, it took several minutes to establish a data connection after I rebooted.
2. My alarm clock app still randomly force closes while in the docking station. I can't even get up on time still.
3. A major issue that was happening before the upgrade and that is still happening...the phone will freeze up and the screen will become unresponsive. This requires me to do a three button restart. When the phone finishes rebooting, my battery charge is drastically lower. This happened today and went from 70% charge right down to 20%. When I look at my battery usage, the Android OS is at 45%.
Any ideas? Has this happened to anyone else?
I had issues with my first phone and most of them stopped after I got rid of two things: EX launcher, and that infernal verizon Backup Assistant. there actually is a way to stop it from running, without resorting to a reset/skipping logging in. One morning when I pulled the phone out of the dock, I got a task manager alert that the CPU was getting hit hard. it was stupid ass Backup Assistant. took me a while to find info on how to disable it, and I did.
try Android Assistant to get a better idea of how much CPU is used by Android OS ("System"). Give it a few seconds to "calm down" when checking the percentage on the pie chart.
I don't have EX Launcher. My Backup Assistant (what it actually backs up I still cannot figure out) is only set to do its stuff during late night hours, between 12 and 6 am.
mine usually failed to back up, hence it would be stuck trying, constantly.
slackingfred
