Results 1 to 6 of 6
    Default Extended Battery Freeze
    Whenever I use my extended battery, my Bionic has a tendency to lock up, frequently. It's the Motorola battery purchased from Verizon. Has anyone else had this problem or know a solution? Thanks.
  2. #2
    fdisker's Avatar
    Posts
    Global Posts
    120 Global Posts
    Default Re: Extended Battery Freeze
    Not me. I use the Moto extended battery 2 or 3 days a week and do not perceive a difference in phone stability between the two.
    Quote Originally Posted by fdisker View Post
    Does your extended battery back stay on well? Mine sometimes does not click in place well. Perhaps I have a lemon (battery).
  4. #4
    Had the same problem, then the phone wouldn't work at all after a while. I think the weight of the battery does something the the contacts on the battery making them freeze the phone and eventually won't work at all. I returned the battery to Moto and haven't had the problem since.
    Thanks for your responses. I'll start by trying to replace it at Verizon and see if a new one makes a difference.
  6. #6
    Default
    I had this same problem on a D2G, but haven't yet needed the extended battery on the BIONIC. I didn't believe that the battery was causing the problems I was having until someone convinced me to swap it out.
