Results 1 to 5 of 5
    Boogan1's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default problem with Go SMS Pro
    I have a couple of issues with Go SMS Pro. First off, for some reason it won't let me receive any texts with attachments. No jokes, pics, nothing. It was working but now it isn't. Also, how do I turn off that damn predictive text or auto correct? It is driving me crazy!!! Thanks for any help.
  2. #2
    DaleGriggs's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: problem with Go SMS Pro
    "That damn predictive text or auto correct" is your keyboard, not Go SMS. Look in the options of your keyboard to turn it off.
    Boogan1 likes this.
    Boogan1's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    YAAYYYY!!!! Thank you!!!! Now if I could only figure out why it isn't reveiving attachments I will be a happy camper!!
  4. #4
    Aiza Flores's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I just wanna ask how can I remove or change the auto corrective text?
  5. #5
    Christopher Matthews Jr's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Quote Originally Posted by Aiza Flores View Post
    In settings, go to language and input, and there should be a 'spell checker' option you can disable.
    Tapped from my Nexus 10.1
