Make sure your sd card is seated properly, not ascue. This causes battery drains and heat at about 50% per hour. People who have two batteries and switch them out are more susceptiable since the battery isn't very easy to pop out and the risk of moving the sd card is higher. I have two batteries , and this occurred twice for me, both times the sd was moved. The last time only by a very small amount. Suggest that whenever your in the back of the phone make sure the sd card is seated and true to position.
