Android Forums at AndroidCentral.com >  Verizon Droid Forums >  Droid Bionic > Battery Drain Since 902 Update
    Thread Author   #1
Old 02-21-2012, 11:11 PM
Activity: 1/20
My battery is draining much faster since the update. Has anyone seen this as well? I took it off the charger (fully charged) nine hours ago and and am at 30%. The OS has used 41%, then the display at 25%.
I use just a Tweetdeck widget. I have the update interval set really low. Use is light lately due to work being very busy. Maybe a few texts, some looking at Tweetdeck, one check of Facebook. Has anyone with VZW talked to them about this?
  #2
Old 02-22-2012, 03:10 PM
Device(s): HTC T-Bolt, Droid Bionic
Activity: 1/20
In the thread that is currently above this one,
Since update...
Beginning around the 4th or 5th post this issue is discussed. Farther down in the thread, I think on page 2, I posted instructions on how to wipe the system cache partition. Doing this seemed to have a positive effect on my stock battery after the 902 update.
    Thread Author   #3
Old 02-23-2012, 11:49 AM
Activity: 1/20
I saw that and I think believed it to apply to rooted phones, which mine is not. I tried it and it has made a big improvement. Thanks!
  #4
Old 02-23-2012, 11:55 AM
Activity: 1/20
Quote:
Awesome! I'm glad it helped. This is something I read about that's actually for those of us peeps who have remained stock.
Reply
Thread Tools Search this Thread
Search this Thread:
Advanced Search
