Results 1 to 6 of 6
    SirGeorgeKillian's Avatar
    Posts
    Global Posts
    366 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Couldn't be happier with battery life!
    I rooted and am running Eclipse, that along with the extended battery has given me the best battery life I have had since the days before before Edge! I take no precautions to extend battery life other than keeping bluetooth turned off as I currently have nothing that uses it. Even with the battery draining 4G and my inability to keep my phone out of my hands, I have yet to have a day go by where my phone has died. In fact even on my longest days, when I plug my phone in at 0100, I am usually still in the 30% area. Before I rooted and did the extended battery, I was lucky to see 1800 before the phone was dead and on life support. I rooted and did the battery swap within 24 hours so I'm not sure which one helped the most. Just thought I'd share and see if it helps anyone else!
    Sent from my DROID BIONIC using Tapatalk 2
  2. #2
    roddhall's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Couldn't be happier with battery life!
    Rookie question: What is Eclipse?
  3. #3
    TerryD's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    It is the battery that is doing the job. GPS and streaming are still killers.
  4. #4
    doogald's Avatar
    Posts
    Global Posts
    4,716 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    So you're saying that if you had even better battery life you wouldn't be happier about it?
    Posts
    Global Posts
    366 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Quote Originally Posted by roddhall View Post
    It is a rom to use after you root. It is the easiest way to make your phone preform like the paper pushers at moto and Verizon wont let it do. Read up on the sections above on rooting. I just learned how to do it and was happy I did.
    Posts
    Global Posts
    366 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Quote Originally Posted by TerryD View Post
    I never turn the GPS or 4G off, and am on 4G sometimes for the entire day. I use google maps quite a bit and stream youtube and pandora to help get me through boring days at work.
