- 10-22-2012, 10:17 AM
Thread Author #1
battery life.....
does anyone have any suggestions on how to improve battery life with ics.I have the extended battery I rooted the phone and.calibrated the battery but still getting terrible battery life even with moderate use.I have a 4g signal all the time.but no wifi during day.
By 7 hours with minimal usage only web searches my battery is down to 40%. Someone please any suggestions lol.. with gingerbread I never had this problem. - 10-22-2012, 11:34 AM #2
- 10-22-2012, 03:31 PM #3a.k.a. RyZR from HoFo
Motorola DROID Bionic (6.7.246.XT865.Verizon.en.US, Ice Cream Sandwich 4.0.4)
Google Nexus 7 (JDQ39, Jelly Bean 4.2.2)
What other devices have I had? Here's my phone timeline.
Support your favorite Android app and game developers. Pay for apps! And don't block ads! - 10-22-2012, 05:00 PM #4
- 10-22-2012, 06:29 PM #5
Re: battery life.....
]It's really hard to tell based on that screen shot since the percentages are all relative to each other. Typically though, "Screen" uses the highest percentage.
Can you tell us or post screenshots of the specific entries (e.g. - show us the stats that pop up when you press "Screen - 26%")? If your SCREEN stats read something like 4-5+ hours of display being on and you had 4G running the whole time, then your battery life isn't too bad for such heavy use. But if it's under 3 hours, then I'd say either your battery is defective or you'll need to do (at MINIMUM) a cache wipe when the phone is fully charged or--at worst--a factory data reset to get rid of all remaining "ghosts in the machine" from Gingerbread.
Personally, I've noticed poorer battery life on ICS--particularly today. I had 11-14% left according to my downloaded battery indicator widget. I then streamed a 2.5 minute trailer for the new HITCHCOCK movie on YouTube over 4G, and suddenly my phone was at 4% power!! I'm hoping a cache wipe fixes the problem, which always has when I've encountered battery life issues following software updates.
EDIT: OOPS! I just noticed you said that you've already done a factory reset, so I doubt a cache wipe will do much. My comments regarding actual display time (indicating how heavily you're using it) still hold true though. You could also rule out whether or not it's a defective battery by installing the original battery. No, it won't last as long as your extended battery, but if you get results close to your current ones or better results on a smaller battery, then I'd assume it's the battery. - 10-22-2012, 07:02 PM
Thread Author #6
My Extended battery worked fine on gingerbread which led me to believe it was ics causing the battery life issue. Everyone said there battery life improved with ics that's why I was concerned . My screen usage is at 2 hours and 30 mins and I was down to 20% when I got home from work. I've wiped cache , I've recalibrated the battery I am just so disappointed with how fast the battery is draining. I go to 90% after 10-15 minutes of web use.
- 10-22-2012, 07:03 PM #7
- 10-22-2012, 07:43 PM #8
OUCH! No disrespect meant to your plight, but I really, REALLY hope you have a defective battery! After all this time, it'll cause a major PR incident among Bionic owners if this long overdue ICS update wrecks that much havoc on a significant number of phones!!
Hopefully, the system just needs to settle in a little bit more, and within the next few power cycles, everything is running in top shape for those of you experiencing problems. - 10-22-2012, 07:46 PM #9
appmy, I just had another thought occur to me. I looked at your screen shot again and noticed two things:
1. Did you have Wi-Fi and 4G running simultaneously? That could drain power faster.
2. I saw the Smart Actions icon in your status bar. Perhaps there is a rule or set of Smart Action rules that are causing the excessive power drain. Personally, I'm not using the Smart Actions app, and even with my noticeable reduction in extended battery life, I still got roughly 31 hours until I hit 3%. - 10-22-2012, 08:14 PM #10
Correct. I had both on to compare it with both on with GB. I had a good history of 16+ hours with both on with Gingerbread.
You are correct. I was playing around with Smart Actions and will turn the rules off and try again tomorrow. I would love to get 24 hours let alone 31. I have never been close to either. - 10-22-2012, 08:22 PM #11
- 10-22-2012, 08:37 PM
Thread Author #12
I've had ics for about 2 months now and the battery life has always been alot worse then on gingerbread! I was hoping the final build would solve it for me but to no avail. I had 2 1/2 hours of screen time on web searching throughout the day with 4g all day and was down to 20% after 11 hours
- 10-22-2012, 09:04 PM #13
Sigh...that's not good. I was hoping I could change my usage patterns with ICS, but I guess I won't be if battery life is that bad. Those patterns would be Wi-Fi only when at home (and even then I use my computer whenever possible) and I keep 4G disabled unless I'm actively using it. The problem there is that I miss MMS messages, which includes multiple-recipient text messages that my supervisor occasionally sends out to those of us working off-site.
My phone should be nearly charged now, so I'm going to wipe the cache and will try to remember to post specific screenshots of my usage when the battery is near depletion. - 10-22-2012, 09:10 PM
Thread Author #14
- 10-22-2012, 09:17 PM #15
Thanks for the tip, just set up a smart action when I'm home on wifi to disable 4g. Never even thought that even connected to wifi that 4g would still be 'on' trying to connect. Sometimes smartphone- dumb operator!
Sent from my DROID BIONIC using Android Central Forums - 10-22-2012, 10:07 PM #16
It's no secret that 4G is a battery hog. Also, GB didn't fully use both cores of the processor, which ICS does along with upclocking a couple hundred MHz. That its also likely to increase power consumption over GB. I have heard many people say the OTA ICS build has much improved battery life vs the earlier leaks, but not sure how it compares on average to GB.
I leave mine plugged in most of the time anyway, so I don't have enough use on battery to know how my life has been from 905, 232, and now to OTA 246. - 10-22-2012, 10:35 PM #17
- 10-22-2012, 11:00 PM #18
- 10-23-2012, 01:24 PM
Thread Author #19
- 10-23-2012, 07:09 PM #20
Battery life is horrible today on ICS. Intolerable with the extended battery. I hope the Razr maxx Verizon is sending me is going to have much better battery life, more like the battery life I enjoyed on my bionic on gingerbread
Sent from my Nexus 7 using Android Central ForumsSamsung Note 2 and Nexus 7 - 10-23-2012, 07:27 PM #21
Yeah, this battery life isn't very good at all even after the cache wipe. It may be as good as Gingerbread on a good day, but it's definitely not better.
I'm currently at 44% after 22 hours, but here are the conditions I've put it under:
1. 4G and Wi-Fi turned off unless I need them.
2. About 6 of those hours, I was sleeping and only had it running for the alarm clock.
3. Display time is 2 hours 3 minutes with the brightness around 40%
4. I did have PlayerPro (my MP3 player of choice) playing almost continuously for 4 hours today.
5. Bluetooth has been on for about 4-5 hours total, but it's usually just on standby and not actively running because I only pair with the Bluetooth system built into my car.
Looking at my stats and the drainage in real time (I use "Battery Indicator" which measures 1% increments in the status bar), I noticed two things:
1. Rate of battery depletion at least DOUBLED when 4G was switched on. It didn't seem to matter what environment (inside, outside, etc).
2. I have two lengthy segments of YELLOW in the bar graph under "Mobile Network Signal". I know exactly where I was during those times, and I have never seen signal weakness recorded there while running Gingerbread. This leads me to believe that the 246 build actually REDUCED my phone's reception, and it's having to try harder to keep a strong signal.
Now, I am grateful that we have a smoother running operating system. I'm happy that my GPS functions again (905 basically rendered it unusable). I'm happy that the screen resolution appears sharper and more vibrant.
However, I'm greatly disappointed in the power management of this build, the reduced reception, and...yes...there have been three times since Saturday night that my phone has dropped data. It's not even close to the instability my 905 had been exhibiting over the past month, but it's still a disappointment.
Hopefully, these problems end up being widespread, and Motorola is forced to design and release a software patch to address these issues.
But...I'm not holding my breath. Maybe the OS 4.1 update will yield better results. As for now, I'm going to have to make sure I recharge every night and also keep it plugged in and charging while driving.
- 10-23-2012, 07:58 PM #22
- 10-23-2012, 08:38 PM #23
OK so here are the results of the "tests" (and I do admittedly use that word loosely) I just did.
Since my battery app can measure 1% increments, I asked my wife to use the stopwatch on her Incredible 4G the moment I hit 39%. I immediately went into Google Reader and randomly opened links in Chrome and casually browsed the articles just as I would in everyday use. I was able to go for approximately 2 mins 15 sec before dropping down to 38%. If that rate was to stay consistent (again, this is a very un-scientific test), I would get around 3.8 hours of web browsing on 4G. Personally, I can't imagine a day where I'd have that much time available to me anyway--especially on a capped data plan.
Now...here's the interesting part. I can't explain why, but I just have a strange feeling that Smart Actions has something to do with this. Prior to this test, I disabled that app. So I decided to re-activate the Smart Actions app, which seems to run even if you haven't established any rules in it. Halfway through the test, my 4G got hung up and stalled again. Maybe it's a coincidence or maybe not.
My suggestion then to those experiencing bad battery life would be to try disabling the Smart Actions app and see if you notice any change. Like I said, it's just a strange feeling I have, but it couldn't hurt to try. - 10-23-2012, 08:52 PM #24
- 10-23-2012, 08:55 PM #25
Battery life terrible?
By bilobi in forum T-Mobile G1Replies: 20Last Post: 04-02-2013, 01:48 PM -
Samsung Moment battery life
By IIJBII in forum Samsung MomentReplies: 97Last Post: 03-21-2012, 08:48 PM -
Improving Battery Life on Your Android Device
By ERDude in forum HTC HeroReplies: 32Last Post: 02-04-2010, 12:33 PM -
battery life
By kunak83 in forum Motorola DroidReplies: 42Last Post: 11-29-2009, 11:28 AM -
Anyone's Battery Life Getting BETTER?
By Christopher in forum Motorola DroidReplies: 28Last Post: 11-20-2009, 11:04 PM
Reply
