DEAL OF THE DAY: Save 43% on the Seidio SURFACE Case (with kickstand) for HTC One!
Results 1 to 20 of 20
    nathans77's Avatar
    Posts
    ROM
    4.0.4 | 6.7.246.XT875
    Default Battery normal?
    I wanted to let others look at my battery info. I know i used to go home at end of day with a half battery left on GB. On ICS, I'm coming home under 30% with normal use as before. I've wiped the system cache, and the last thing to do is a reset but would that definitely help?
    Sent from my DROID BIONIC using Android Central Forums
    Attached Thumbnails Attached Thumbnails Battery normal?-uploadfromtaptalk1351195138601.jpg
    Droid Bionic (Stock) | Android 4.1.2 | 98.72.22.XT875
  2. #2
    Default Re: Battery normal?
    Did you disable 4g on GB but not doing that now on ICS? I don't think a reset would help. You could also of installed something that is effecting it.
    nathans77's Avatar
    Posts
    ROM
    The only things different, are that I've uninstalled a bunch of apps that ICS makes redundant. 4G has been on while I had GB.
    nathans77's Avatar
    Posts
    ROM
    Here's a CPU Spy pic
    Attached Thumbnails Attached Thumbnails Battery normal?-uploadfromtaptalk1351199122680.jpg
    nathans77's Avatar
    Posts
    ROM
    And here's another battery shot. Do the percentages and order of things look right, or is there a definite hog?
    Attached Thumbnails Attached Thumbnails Battery normal?-uploadfromtaptalk1351199509320.jpg
  6. #6
    Woah!! On most devices the display should ALWAYS be first and foremost with the highest percentage of battery use! I'm not completely sure but I know when I upgraded my devices to ICS the Android Operating system ranked very high for the first few days and slowly went back to normal. Is this the first day or two with ICS?
    Sent from my DROID RAZR using Android Central Forums
    nathans77's Avatar
    Posts
    ROM
    It was finishing OTA update around 8am on 10/23/2012. I thought mine looked odd, because all the other shots across the internet of that screen had "Screen" first and the OS second.
  8. #8
    I just looked and noticed similar behavior on my just updated bionic, with the OS taking 47% of my battery. Hopefully it is just a temporary issue.
  9. #9
    mwohrlin's Avatar
    Posts
    Global Posts
    148 Global Posts
    I kind of noticed the same thing when I went from GB to a leaked ICS. But overall it still wasn't bad. Even though I didn't notice it, I probably did use my device a bit more during the day because it was so much nicer to look at compared to GB.
  10. #10
    10/23/12 is fairly recent so I wouldn't jump the gun and do a factory reset YET (You have to give the Android OS time to settle all the newly updated files)! However if it continues for say another week or two then it might be your only option. If you do have to resort to a factory reset I recommend AppMonster to backup and restore all your apps (it actually backs up the original .apk incase the app is no longer offered in the store or if you downloaded / installed from alternative sources). I know it seems like a daunting task (I just had to reset my Razr after flashing Google Now) but Google and other 3rd party apps have taken a lot of the hard work out of it!
    EDIT:
    I also forgot to ask what it was showing under display for time on (kinda hard to explain but goto the same screen you were on where it shows what has been using the battery and then tap on the entry for display or screen and it should show up right there).
    Thanked by:
  11. Thread Author  Thread Author    #11
    nathans77's Avatar
    Posts
    ROM
    Is this what you were asking for?
    Attached Thumbnails Attached Thumbnails Battery normal?-uploadfromtaptalk1351215268253.jpg
  12. #12
    Yup that's it and it looks about right being at 21% for around 8 hours.
  13. Thread Author  Thread Author    #13
    nathans77's Avatar
    Posts
    ROM
    Ok, I'll let it sit for a couple weeks and see what happens. It's been on since 7:30am. I've had a lot of app installs before, and now I'm down to a handful of apps. So if it comes to a reset, it shouldn't be that big of a pain for me.
  14. Thread Author  Thread Author    #14
    nathans77's Avatar
    Posts
    ROM
    Ok, it seems to have settled down Friday. Friday unplugged from charger at usual time in morning. Spent 8 hours in concrete and metal building at work. Went home and had at least half battery left.(forgot pic for last night but it just the same as tonight.) Today went well as well. I've used it like i normally would. So it would seem to let it settle at first and see what happens.
    First two are end of Saturday night, last two are Friday morning.
    Attached Thumbnails Attached Thumbnails Battery normal?-uploadfromtaptalk1351393627721.jpg   Battery normal?-uploadfromtaptalk1351393639338.jpg   Battery normal?-uploadfromtaptalk1351393670369.jpg   Battery normal?-uploadfromtaptalk1351393680680.jpg
  15. #15
    DroidST's Avatar
    Posts
    ROM
    .246 ICS
    Android OS still on top and at 34%
    Perhaps it's the new normal for it to be on top of the list (highest usage)
    http://www.speedtest.net/android/82639714.png
  16. #16
    On GB I had my phone set so that after 15 mins of inactivity, background data would turn off and that saved a ton of power. Is there a way to do that on ICS?
  17. #17
    Lefty Drummer's Avatar
    Posts
    ROM
    .246 ICS
    Quote Originally Posted by londonham View Post
    I think you can set up something like that with Smart Actions.
  18. #18
    Quote Originally Posted by Lefty Drummer View Post
    Yeah I saw that but it looks like that the only option there is time based (ie, morning hours, afternoon hours, etc) but I just want it based in inactivity. Any other ideas would be appreciated.
  19. #19
    Posts
    ROM
    .246 ICS
    What if you have your screen set to shut off in a specific amount of time (under settings/display/sleep), then set the smart action to let the display going 'off' trigger data off? I think that would work.
  20. Thread Author  Thread Author    #20
    nathans77's Avatar
    Posts
    ROM
    You can create a smart action to trigger on display off to turn cellular data off. I've tried it, but it would always go to reconnect data when woke up. Basically, when I needed data that moment I had to wait for it to kick on (just a couple seconds, but I want data then lol).
  1. Battery Temp, what is normal?
    By dspcap in forum Verizon Droid Incredible
    Last Post: 03-28-2013, 08:39 PM
  2. WiFi using 5 to 7% of Battery. Normal?
    By Richs10 in forum Verizon Droid Charge
    Last Post: 01-05-2012, 11:42 PM
  3. Replies: 17
    Last Post: 07-19-2010, 06:00 PM
  4. Is this normal battery life ?
    By OrderedtheEvo in forum HTC EVO 4G
    Last Post: 07-08-2010, 07:04 PM
  5. Advanced Task Killer Battery drain is this normal?
    By cheebahawk1 in forum HTC EVO 4G
    Last Post: 06-06-2010, 06:54 PM
