maybe im not right???....
Well I went over to my iphone a few months ago while waiting for ICS to drop on my bionic. I finally got the update for it (my phone is still connected to wifi but not to my number) and I downloaded the software and when I went to install it, it wouldnt work. Ive attempted it 4 times and each time, it fails. Now I am thinking I can not update it over wifi and that it has to be actually hooked to my number. I called VZW and they said it should update over wifi (but as we all know, they sometimes dont know what theyre talking about...). I wanted to see the software in action before making my decision to go back to my droid or stay with my iphone... does anyone know if that is the case?:):):):)
Re: maybe im not right???....
Why is this in the Android forum? Should this be posted to the iphone forum?
Sent from my Verizon Galaxy S3
Um no because clearly Im asking a question about my Droid Bionic.
do a factory reset on your bionic and then try the update again.
Sent from my DROID BIONIC using Android Central Forums
Was your Bionic ever rooted? If so, you'll likely need to revert to stock to get the install to complete successfully (that was my experience at least).
We have two Bionic phones in the household. The rooted one ran the update to ICS over WiFi with no problems, the unrooted one failed. I was finally able to flash .246 using the [Only registered and activated users can see links. Click Here To Register...] scripts.
Mine updated over wifi without a problem, and the whole process took about 20 minutes, including reboots and updates. And my phone was rooted at the time and remain rooted. Go figure.
Seriously, give House of Bionic a look. SamuriHL has been making life easier for Bionic owners since the first ICS leaks started to come out, and the process is now pretty well refined.
Indeed. I've yet to hear of anyone that couldn't get ICS to install vita House of Bionic. Even users having troubles got it to work that way.
I suffered the same issues with my Bionic. I actually used House of Bionic to FXZ to the stock Gingerbread. I was then able to upgrade via the OTA - but all-in-all, it may be easiest to just use HoB to move to ICS.
