Hello all,
I am having a problem, and I was hoping someone might be able to help. I needed to replace the digitizer in my wife's Bionic because she spiderwebbed her's and I bought the digitizer from Motorola Droid Bionic XT875 Touch Screen Digitizer Glass New Repair Cracked | eBay. After replacement, everything worked perfectly and I was happy with the install. After almost a day, however, my wife complained that the touch screen wasn't operating properly. After further analysis, it turns out that the right side of the screen (including the "Back" and "Search" softkeys) were not functioning at all. The left side (including softkeys) all worked fine, but the right side wouldn't respond to any touches.
Based on this information, would this be a digitizer fault due to a crappy digitizer or is it something in my install?
If you need any additional information, please feel free to ask.
Thank you all for your time and help.
