Results 1 to 4 of 4
- 01-20-2013, 12:11 PM
Thread Author #1
Headset: in call volume too loud
For most calls using my headset, the lowest volume possible is a bit too loud, but acceptable at least while driving. I even use a Tasker task to automatically turn in call volume down all the way upon plugging in headset. The task seems to work ok as I get the notification upon plugging in, but when I make a call, the first thing I hear is the ring at max volume. If I then hit volume down manually, the volume does not change, but the volume display pops up showing it at the lowest level. If I hit volume up manually, the level jumps down to where it should be. The volume remains where I set it for any subsequent calls made with the headset still plugged in. I really don't want to have to modify my ear buds for a band-aid solution. Anybody else experience this or have any possible solutions?
- 04-12-2013, 09:22 AM #2
- 04-12-2013, 10:26 AM
Thread Author #3
Re: Headset: in call volume too loud
I was on ICS leak when i has this. Now on pacman ROM and it seems better. There is a setting in sounds to lower volume on plugin. I assume all JB builds have it? Check yours.
- 04-14-2013, 01:54 PM
Thread Author #4
Disregard. I thought it went away, but I still have the problem on this ROM. Hardware problem?
Nexus 4 In Call Volume too LOUD!
By fam617 in forum Google Nexus 4Replies: 12Last Post: 03-15-2013, 06:30 AM -
Verizon G-Nex In-call volume too loud
By Major517 in forum Verizon Galaxy NexusReplies: 7Last Post: 12-04-2012, 09:22 AM -
In-Call Volume Too Low Not Going Up...
By AisforAustin in forum Motorola Droid 2Replies: 6Last Post: 06-07-2011, 07:54 AM -
Rooted. Call volume too loud. Is there a way to change volume range?
By DigitallyChallenged in forum Verizon HTC ThunderboltReplies: 2Last Post: 05-13-2011, 09:55 PM -
In-call volume too low on Evo 4g
By gary11082 in forum HTC EVO 4GReplies: 29Last Post: 09-15-2010, 05:24 PM
Reply
